E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - NY / NJ / CT / PA > All the DME Codes for the community!
      02-25-2014, 11:55 PM   #23
robertsawh82
robertsawh82's Avatar
Drives: Montego Blue 335i AT
2007 BMW 335i  [10.00]
Originally Posted by WhiteFury View Post
Hey you told me to pm you. I was using jb4 software on laptop for these codes. What do you think it is?
I just texted my boy, he is a bmw tech... really good with our cars... I never heard of anyone getting those codes... last time I got problematic codes I did a soft reset... took the negative terminal off the battery for 10 minutes and then plugged it back in.... but hold that off until I get a reply back from him!!
Meth, JB4 G4, and DCI's
      02-26-2014, 08:28 PM   #24
WhiteFury
Boooost!
WhiteFury's Avatar
70
Drives: 335i
I got the code 2D1B again today does this mean I need a new pedal assembly?
JB4 Stage 2 | Injen CAI | BMW PE | AR Catless DP | Alpina TCU Flash | Eibach Pro Kit | Custom TCKline Koni's | 19" M359 Wheels | DWS Tires
      02-26-2014, 10:03 PM   #25
Mr.Mastashake
Mr.Mastashake's Avatar
Drives: 07 335i
Subd for later
2007 BMW 335i- stockish for now.. ZHP shifter, VRSF DPs, JB4..
2009 Chevy Cobalt SS- bolt-ons, 18/26psi tune: Easy M3 Killer [SOLD]
      02-27-2014, 12:24 AM   #26
Sidewinderpb
Drives: 2017 340i xDrive 6mt
So maybe your boy can help me with my codes. I only get the normal codes for unplugged exhaust flap (duh) and a downpipe code (also duh), but the car hesitates and stutters. On top of that, it dies at cold start (yes, i installed the flex fuel wires and set the FUE=20). Now I'm also getting a MAF code (MAF has been set back to stock, as JB4 no longer uses it).
      02-27-2014, 12:31 AM   #27
Sidewinderpb
Please click this link if you're having issues; this is a link to ALL of the codes.
http://www.e90post.com/forums/attach...0&d=1311576543
Edit: deleted that last part of my comment. After re-reading it, I accidentally sounded like a dick! Sorry!
      02-27-2014, 03:02 AM   #28
WhiteFury
Boooost!
WhiteFury's Avatar
70
Drives: 335i
Originally Posted by Sidewinderpb
Please click this link if you're having issues; this is a link to ALL of the codes, unlike what is in this thread:
According to this chart the code 2D1B means o2 sensor after catalyst is too lean.
Jb4 says throttle position input position 1?
      02-27-2014, 09:01 AM   #29
Sidewinderpb
Well I'm no professional; just sharing a more complete list of codes.
      02-27-2014, 02:49 PM   #30
robertsawh82
Sounds like a bad Mass Air Flow Sensor! Those are symptoms of that! Hesitation and stutters are two of those problems... Here is what you can do. Unplug your MAF sensor and if nothing happens there goes your problem. Two things, if your manipulating your maf sensor from your jb4 then figure out how to set it back to stock if you have a factory bmw maf. Or you sensor just went and you need a new one. Your MAF sensor is very vital to your engines performance! Your JB4 relies on that information from that sensor!
      02-27-2014, 03:06 PM   #31
robertsawh82
My boy is an a$$... I just called him again and he didn't pick up. He works nights and weekends in a shop if you want to bring it by. Otherwise that try and doing the reset to your car. disconnect the negative terminal for about 10 minutes and then reconnect it! If he calls me back I will PM!
      02-27-2014, 05:29 PM   #32
Sidewinderpb
Oh balls. I actually reconnect the stock MAF this past weekend. Issue is still there though. I thought the JB4 actually doesn't use the MAF with the ISO 5.3 update?
      03-02-2014, 09:38 AM   #33
robertsawh82
Coming from a mechanics perspective, I don't see how that is even possible! The Jb4 needs to communicate with that sensor in order to read if the motor is boosting or not. When it reads that it allows the ecu to compensate for timing and fuel, along with your 02 sensors. I can get more technical but this is more easier to understand. Is there any way you could forward me that information about the MAF, and that update?
      03-02-2014, 09:46 AM   #34
robertsawh82
Also what year is your car(n54or N55) ? Because my car (N54) has a map sensor which is located on the charge pipe close to the throttle body.
      03-02-2014, 11:03 AM   #35
Sidewinderpb
N55
      01-22-2015, 08:40 AM   #36
gregsatt
Drives: 2011 335is
2004 Honda CRF230  [0.00]
2011 335is  [0.00]
This is a great document. Do you happen to have one for the N54?
      02-03-2015, 07:04 PM   #37
homemade_f81
Drives: 2018 340i, 2020 M2CS
I'm asking the same thing. As our cars age, a resource like this is huge - a real $ saver.
      10-14-2023, 07:11 PM   #38
EnzoKhan
Drives: 335xi M Sport e92
2011 BMW 335xi  [0.00]
What is 2D34? I keep getting this? I am also getting 2D1B
I was getting 2D2F and 2BCB, so replaced the upstream O2 sensor, right after that I started getting 2D34 (signal fixed at rich) code. Did you ever find out the cause?
I am also noticing lean conditions in my engine.
Thanks!
e90post
