02-22-2018, 06:58 PM | #23 |
Rep 297
Turner or Fall Line is the best? I think Fall Line is a better design because of fewer pieces. If that's the design that's agreed upon I'll pick one up and change the design by adding the mesh grill and make them out of 304 SS.
Everyone's thoughts? |
02-22-2018, 07:05 PM | #24 |
Rep 297
Yup anything can be done!
02-22-2018, 07:10 PM | #25 |
6586
Rep 5,305
Only complaint I've seen pertaining to the RKP version is that it protrudes down quite a bit lower than the OEM or Turner version. That might not be an issue for people who keep the stock ride height. But for someone like me that is lowered, it's a make/break issue. Other's will have their own opinion on the topic.
02-22-2018, 07:34 PM | #26 | |
Rep 297
02-22-2018, 07:42 PM | #27 |
Rep 2,448
The Fall Line or RKP version is running on IND's previous M3 and current M4.
Their M4 is pretty low and I believe they designed it to protrude out a bit lower so if it flexes it won't hit the cooler. Anyway that's just my hypothesis.
Current Bimmer: '16 F80 M3, '20 F87 M2c Gone but never forgotten: '13 FO e92 M3, Swifts, volks/advan, Akra Evo, Kics R40 Past: Alpine white e46 323i, Jet Black e39 530, Saph Black e60 530, Space Grey N54 e92 335, Mineral White N55 e92 335 |
Caliboy951203.00 warp_ix29.50 |
02-26-2018, 05:06 PM | #28 |
Rep 834
I just installed the Turner Skid Plate and it's definitely made heavy duty. The aluminum is almost a 1/4 inch thick. Everything was stiff when it all went back together.
M Forever!!!!
02-27-2018, 11:38 AM | #31 |
Rep 2,448
Something to consider that I read on the forum from a member who bought the Ind version.
"the "Turner/ECS" model has large open areas and a lotÂ* of unions and rivets which, in and of themselves, could be points of failure and potentially add to the hazard."
02-27-2018, 01:12 PM | #32 |
Rep 834
I don't see how it could fail as it was rock solid when I received it. All the hardware including the rivets and unions are heavy duty as well. No way can it ever move. If you can only hold one you know what I mean.
M Forever!!!!
02-27-2018, 01:46 PM | #33 |
Rep 2,448
Rivets can fail regardless of the how well built the piece seems. Not saying it will but simply stating the possibility as it depends greatly on the mechanical properties.
Current Bimmer: '16 F80 M3, '20 F87 M2c Gone but never forgotten: '13 FO e92 M3, Swifts, volks/advan, Akra Evo, Kics R40 Past: Alpine white e46 323i, Jet Black e39 530, Saph Black e60 530, Space Grey N54 e92 335, Mineral White N55 e92 335 Last edited by swifty; 03-29-2018 at 11:34 AM.. |
03-29-2018, 11:04 AM | #34 |
Rep 108
03-30-2018, 09:53 AM | #35 |
Rep 7
03-31-2018, 11:27 AM | #36 |
Rep 297
08-12-2020, 04:54 PM | #38 |
Rep 3,730
Just got my turner skid plate today. Is one of the sides supposed to be bent like this?
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
08-12-2020, 10:26 PM | #39 |
Rep 1,978
I don't recall any bends when installing mine, but maybe you can just bend it back yourself? maybe it was a shipping issue? Best case is to try and test fit it as its super easy to install.
08-12-2020, 11:06 PM | #40 | |
Rep 3,730
08-13-2020, 12:50 AM | #41 |
Rep 1,978
08-13-2020, 01:42 AM | #42 | ||
Rep 239
