BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Suspension | Brakes | Chassis
European Auto Source (EAS)
      02-17-2012, 02:08 PM   #23
embacpa
Drives: 2011 M3 Sedan
i think the arms are plenty strong, it seems the bushings are not equally matched. i have had my alignment checked 3 times over 4000 miles and the camber is dead on, yet the toe has been out of spec each time. my dealer is checking with the engineers. i have a sedan, not a coupe.
      02-17-2012, 04:28 PM   #24
RickyBobby
RickyBobby's Avatar
108
Drives: M3
Am I the only one who thinks these items are entirely unnecessary for a new well maintained car? I run my car competitively in NASA and don't think the car has any deficiencies that would cured by these parts. The only part I think would actually help the car go faster would be solid subframe bushings if you go crazy with rear spring rates.
Once the stock bushings start to wear out, these items would be a good upgrade, but for a new platform like the e90, I'd argue that they would produce any tangible difference.
      02-17-2012, 04:53 PM   #25
embacpa
i agree. i think it should suffice. however, my toe will not stay in spec. hopefully puma case will resolve it.
      02-17-2012, 07:45 PM   #26
bigjae1976
bigjae1976's Avatar
1581
Drives: 11 E90 M3 Individual
2004 BMW M3  [4.50]
2011 BMW E90 M3  [5.25]
2013 BMW 328i  [5.00]
I agree. Some think stiffer is always better (that's what she said) but definitely not the case as I've found out with the poly E46 RTABs. I do think that some well thought out upgrades will make a difference...like the solid rear subframe bushings.
The E9X seems to like to rotate more than the E46 in stock form...which is what most people try to achieve in the E46 through upgrades...less understeer.
I think this car is surprisingly tail happy for a BMW. Which is why I want to try the toe links.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue
2004 E46 M3 Imola Red
2000 E36/7 Z3 Steel Blue
      06-22-2012, 12:43 AM   #27
Triple M
Doc Rebel!
Triple M's Avatar
Drives: Fire Orange M3, X5M, Blk 135
Judging by the little difference in "performance numbers" between the GTS and the competition package E92, it really does make you wonder.
      07-24-2012, 11:12 PM   #28
neilvosko
neilvosko's Avatar
Drives: 335i e92 FBO
+1
      01-04-2013, 04:17 AM   #29
lukester
Germany
314
Drives: BMW M3
Anybody running any of these parts and willing to write some feedback?
      01-04-2013, 08:36 AM   #30
klammer
Drives: 11 spc gry m3 e90, 19 X5
Had the monoball control arms and delrin subframe bushings put in the car this fall as well as RD sport sways F&R and love the upgrades. Will right a more thorough review, but with the control arms, steering feels heavier, like servo is set to sport when in normal, and car is definitely more solid feeling with the bushings and feel the car is a bit flatter with the sways. Looking forward to others impressions as well...
mods: track ready stuff
      01-04-2013, 09:58 AM   #31
bigjae1976
bigjae1976's Avatar
1581
2004 BMW M3  [4.50]
Forgot to add some feedback. I had the dinan toe links in and they are totally unnecessary. Re-installed the OEM arms and sold the dinans. I guess if you are constantly adjusting rear toe then they would be great but who does that?
The only major upgrade I'll do are the solid subframe bushings. Otherwise all seems fine.
      01-04-2013, 06:00 PM   #32
paradocs98
paradocs98's Avatar
Drives: M2C
Disappointed to hear that, but I'll see what I think this spring. I had the Dinan rear toe links and front monoball kit installed a couple of months ago while my middle exhaust and software were being done (Dinan was running a 15%-off promotion).
Past: E46 330Ci, E60 545i, E60 M5, E90 M3
Present: 2020 M2 Competition, 2022 GT3
      01-04-2013, 06:35 PM   #33
bigjae1976
bigjae1976's Avatar
1581
2004 BMW M3  [4.50]
I saw a video from a car that was behind me when I dropped a wheel. I could see the back end just really squat under acceleration and then I dropped a wheel off the pavement and the backend just bounced like a pogo stick. I'm even more convinced that the non EDC rear suspension is (even with dinan springs) is too soft. I guess that Dinan made the toe links to add some stability...which I think it might help...but the toe links aren't the problem. The problem is the weight and the soft rear suspension.
When I put the OEM links back in...I really couldn't tell a difference.
      01-07-2013, 04:24 PM   #34
mlhj83
Scythe-Meister
mlhj83's Avatar
Drives: '11 E92 M3 ZCP | F80 M3 CS
Question, is there any difference between the rear subframe (apart from solid bushings) and unibody of the GTS and the production M3? I'm hesitant of putting solid subframe bushings as logic would suggest additional strain on the rear unibody subframe mounting points with solid bushings.
      01-16-2013, 03:22 PM   #35
MikeR1994
Drives: 06 e90 325i, 05 325Ci (RIP)
2006 BMW 325i  [0.00]
I'm fairly certain that solid mounts would actually put less stress on the unibody than rubber. Think of it this way: if the mounts don't give, force is applied in a relatively equal manner across the subframe. But if the mounts DO give force can be isolated in one area of the subframe, generating more shear force, and tensile force, on the bolt ad the mounting position on the unibody.
I could be totally wrong. Just thought I'd implement what I've gathered from my first semester of engineering classes. Haha
-Michael
Active Autowerke Stage II | MMW CSv2 Exhaust | MMW Catless Headers | BC Racing BR Extreme Low Coilovers | custom adjustable rear suspension links | 19" Hyperblack CSL's | M3 style front | trim wrapped in brushed steel vinyl | Slightly smoked tail lights with clear reverse lights | factory xenons
      01-29-2013, 09:28 PM   #36
ki__
Drives: 19 M2C 6MT
Awesome thread
Might pull the plug on the rear bushings.
      01-29-2013, 09:53 PM   #37
Car54
Drives: 2014 M-Sport Wagon - EBII
In for more!
      04-26-2013, 09:24 PM   #38
Triple M
Doc Rebel!
Triple M's Avatar
Amazing thread! will never get old. Amazing how many e9x M3 getting tracked, so few with experience with this suspension products. Thanks guys
      06-28-2013, 04:06 PM   #39
Ant Man
Drives: E92 M3 Individual Edition
Powerflex now produce a 'black' version for a number of M3 bushes including the rear subframe.
      07-03-2014, 09:45 AM   #40
bryan292009
bryan292009's Avatar
Germany
67
Drives: 2011 E90 M3 W/ ZCP, ZPP, ZCW
I recently installed the TMS solid sub frame bushings and Delrin diff bushings and a KW sleeve kit ( insert comments) I know but I wanted to keep the EDC! Also installed Challenge rear toe arms and a Dinan front sway and camber plates and rear upper shock mount for added travel and lastly a H&R rear sway. I do not track a lot it is my daily driver and I live in WI so it sees lots of varying driving conditions. I am totally pleased with it. There is more NVH but it is not that bad! The rear end feels more planted and the feedback is way better! It was all installed at iND great customer service and exceptional workmanship!
E90 M3 W/ ESS VT2-625, Macht Schnell race X-Pipe, UUC Cat-back exhaust, Stoptech ST60
      07-03-2014, 10:18 AM   #41
aus
Drives: Odysse
Thanks for the input. You can't seriously recommend improving the driver instead of "improving" the car???!! Blasphemy!!
Good info. I was thinking of getting some toe links.
Are the Black one's stiffer??
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
      07-03-2014, 10:20 AM   #42
italyix
italyix's Avatar
Drives: '08 E90 M3
How many miles do you have on the car? I have same mods (for now) minus the Challenge arm and have RD Sport Sways, and KW Springs on for ~15k miles already (car now has 73k miles) and I feel the rear end now does not stay connected when turning fast and the road is slightly uneven. I have some oversteer now, I think the shocks might be on their last legs.
      07-03-2014, 10:27 AM   #43
bryan292009
Germany
67
I have 45,000 on it now!
      07-03-2014, 10:28 AM   #44
bryan292009
Germany
67
Yea, have read that the EDC shocks start to wear out around 75,000!
m3post
