10-27-2013, 09:07 AM | #25 | |
Rep 898
Drives: '69 GT3, GT4, 1M, 912
Also beware the difference fresh rubber makes. Simply switching from old PSS to fresh PSS would make you swear the tires are completely different. PSS Rears in stock sizes, yes. Not clear if that size is being updated or what.
1M, GT4, 1969 Porsche 911 w/ 997 GT3 Cup Motor (435hp & 2,100 lbs)
10-27-2013, 10:42 AM | #26 | |
Rep 2,898
Neil |
10-27-2013, 09:47 PM | #27 | |
Rep 898
For some more background read this about traction control: http://www.motortrend.com/features/p...ction_control/ Or this PDF paper on tire modeling describes it on page 5: http://www.engr.colostate.edu/pts/Jo...20Modeling.pdf
10-27-2013, 10:05 PM | #28 | |
Rep 2,898
Neil |
10-27-2013, 10:34 PM | #29 |
Rep 898
"Spinning" is relative, but this is not just a drag strip thing. The wheel is always turning faster (or slower) than the road if you're putting force through it. In 2nd gear acceleration it's probably about 5%, at top speed it might be 1-2% (to combat the aero drag). The tire moving exactly with the road is an illusion at all times if you're pushing it.
10-27-2013, 10:39 PM | #30 |
Rep 3,070
Don't know if this is absolutely correct or not myself but regardless it sounds to me pistonhead poetry with a philosophical twist, nice phrase
"The mark of a great car is one whose overall competence exceeds what you should expect from its individual components and the 1M does just that", Chris Harris.
BMW 1M-SOLD-: TECH: Evolve Race+N55mids, Evolve IC, Michelin PSS, ER cp, aFe filter, CDVx, Vorshlag camber plates, BMS OCC EXTERIOR: trunk spoiler, blacklines, black grills, IND goodies INTERIOR: Alcantara steering wheel, steel pedals, custom mats, MPower e-brake. |
10-28-2013, 08:04 AM | #31 | |
Rep 2,898
So, how then does the odometer, speedometer and ABS/DSC compensate for all this? Neil |
10-28-2013, 08:55 AM | #32 | |
Rep 898
Consider: you're trying to apply a force with rubber, so effectively a spring. And you can't push on something with a spring without deflecting that spring. When a tread block arrives in contact with the ground it's undeflected, but shortly afterwards it's trying to transmit roughly 2000 lbs of forward thrust to the pavement at peak acceleration in a 1M. It deflects, then springs back when it leaves contact with the road. On a micro scale the rubber itself is doing the same thing. Hence even if the rubber on the bottom of the tread doesn't move relative to the ground, the overall tire does. See the second reference: "In contrast to slip angle, which is slip in the transverse plane, the slip ratio is the slip in the longitudinal plane. The slip ratio affects acceleration and breaking and therefore bears analogy to the slip angle in the sense that as slip angle is related to lateral force, slip ratio is related to longitudinal force and traction capacity. Generally speaking, the coefficient of friction will change with changing slip ratio. A plot of coefficient of friction vs. percent slip increases nearly linearly up to about 5% slip, peaks near 10% slip and then falls of in a nonlinear fashion (Ref 2). The definition of slip ratio used here is the equivalent of the SAE definition." Every tire/ car combo is different, so there is no generic "best" slip percentage. Data from a particular combo looks like this: Notice there is no flat spot in the middle of this graph. Now if you're just coasting the tire is going to be transmitting zero force, either longitudinally or laterally, so no slip. But as soon as you ask the tire to transmit forces, either braking, accelerating or cornering, the tire must begin to slip, a small amount at low force, a large amount at large force, Odometer doesn't compensate and doesn't need to- tire OD plays a bigger factor, etc. Speedometer is driven from the front wheels, so no incorrect reading unless you're braking. It plays a critical roll in ABS and especially DSC function, however. You know how the 1M comes with a warning that says you need to keep the .5" stagger between front and rear wheel OD? This is why. The DSC is reading the rate that the front and back wheels are turning and calculating the difference. It's targeting a maximum of some percentage difference in ground speed, perhaps 5% in MDM mode. If the rear tires are at 5% difference that's fine, you're near max acceleration. If it's more than 5% difference it shuts the fun down. In normal mode this percentage difference is reduced, maybe it's more like 3% difference. Again, see the first link I posted above for more of explanation. An excerpt: "For most road legal tires, the peak mu is usually somewhere between 0.85 and 1.0 and it peaks in the 5-20-percent slip range. Maximum traction is achieved at the peak of the mu-slip curve and the engineers that calibrate ABS/TCS systems generally try to control their systems to keep the tires slipping somewhere around that peak to achieve top performance. In general, traction control tries to manage the slip on the drive wheels near the peak of the mu-slip curve in order to preserve stability and keep the car from sliding around. It does this by monitoring parameters like engine torque, gear and throttle position, and the driven and undriven wheel speeds to determine when the drive wheels are starting to spin up and break away."
10-28-2013, 09:34 AM | #34 |
Rep 108
Is it possible that the 'slip' you mention may sometimes present itself as sidewall deformation rather than a relative difference in speed between the wheel and ground? I haven't read either of your links yet, but I am still struggling with believing that a wheel experiencing acceleration or deceleration at the minimal amount is still experiencing 'slip'. I've always thought that the sidewall deformation played a roll as well.
1996 Trans Am WS6 (RiP)
2002 Trans Am Collector Edition WS6 - Not Stock @ 425 rwhp 2006 VW GTi - APR Goodies - Sold 2011 1M - VO Florida pick up 11/4/11 #554 of 740 - Sold 2017 ATS-V Stock |
10-28-2013, 09:55 AM | #35 | |
Rep 898
That it is...
If you look at that graph above, if you're close to zero friction, which is what you'd be if you're just pulling away from a stop normally at low acceleration, you're also close to zero slip, so imperceptible. Even a few percent slip is going to be difficult to both feel and see, and that's all you'd experience in many cars at close to max acceleration. The 1M is powerful enough to get to the part of the curve that starts to flatten out in second gear, at which point you can feel it if you're sensitive.
10-28-2013, 10:59 AM | #36 |
Rep 173
Does this slippage only apply to when a tire is rotating while generating a horizontal force or does it also come into play with a stationary tire such as when your parked on a hill?
I ask this to understand how the slip ratio chart posted would apply to a rear tire going through a turn with no brake or power being applied and where the traction force is being applied to the tire is not in the direction of travel (low trust directional travel compared to the slip direction travel)? Last edited by scotth944; 10-28-2013 at 11:33 AM.. |
10-28-2013, 11:40 AM | #37 | |
Rep 898
If you are only cornering, not accelerating or decelerating, you'd be at 0/0 on the longetudinal slip chart, but you'd be somewhere else on the lateral slip chart, which is similar in concept but different in scale and values due to tire shape and construction.
12-15-2013, 02:04 PM | #40 |
Rep 13,167
Recently forum fellow ///Nordschleife mounted PSS on his 19" BBS CH-R rims: 255/35 R19 front | 275/35 R19 rear (instead of 245/35 R19 front | 265/35 R19 rear).
He told me he's very pleased with it. Lots of grip (dry and wet). Significant difference with PS2. Like many of us, also his 1M got the front fender liners upgrade (http://www.1addicts.com/forums/showthread.php?t=682196): only minimal contact/rubbing at full lock with the 255/35 R19 front wheels. Any others have experiences with a PSS 255/275 setup ?
///M is art ↔ Artemis
12-17-2013, 03:07 AM | #41 |
Rep 9
12-29-2013, 12:57 AM | #42 |
Rep 153
Drives: 2012 BMW 1M Coupe VO!
I am at 64500 km and will go for a tyre change today after work. My rear right tyres has a major personality defect keeps loosing pressure. Been running the same tyres that came with the car since feb 2012. They are down to 1mm from the thread wear indicator. I will go PSS 255/35 front and debating 275/35 or 285/35 rear. Can't wait to feel the new grip. I pack highway miles mostly and some mischief on empty back roads.
Daily Driver: 2012 BMW 1M Coupe Valencia Orange / 2015 Golf R Torando Red , DCT
Weekend Beast: 2012 Audi R8 GT Frozen White #281/333 |
12-29-2013, 09:36 AM | #43 | |
Rep 3,070
If you want a wider alternative to 275/35, PSS comes in 295/30 which would be my choice over 285/35.
12-29-2013, 11:18 AM | #44 |
Rep 153
would it fit nicely? I am so scared to go that wide on stock rims. I will check it out. Having rubber that phat in the back would be
