      11-04-2012, 07:29 PM   #23
M3 Adjuster
Albania
7909
Drives: 1M, X1 M Sport, E46 325ic
Originally Posted by Hobbe
Originally Posted by bdaddylo View Post
You're absolutely incorrect. There is no way you can get -1.5 in the front without removing the pins and lowering the car. .
Well, lets see if I can find that piece of paper again.
Please do
      11-07-2012, 10:57 AM   #24
LotusBoy
Drives: BSM 1M, N55, KW's DDC
Originally Posted by Mahlzeit View Post
Thanks guys - this is really helpful.
I did just swapped out my PS2's for stock sized PSS.
I consider myself an intermediate track driver - have experience at Sears Point, Big Willow, Laguna Seca in DE's and a formal 3-day school. In my modded e36M3, Barber Mx5, and shifter karts.
Looks to me at least -1.5 is achievable w/out camber plates, but on a lowered suspension. If I go this route (say w/ KW V3), I'll only have to worry about keeping myself on a leash and not bombing each corner and rolling the fronts over on themselves. Budget permitting I like to save that type of driving to rented and insured equipment.
Hi ! I went to my Bimmer specialist to say hello. He's an engineer and is racing as well. He told us that pulling the pins would allow at least 0.5 degree extra negative camber. Maybe more, but he hasn't done it on a 1M yet. My mate was there, too, and after 12000KM on them, his front PS2's are shot due to outer and center wear. He did 4 track days this year. I'm starting to consider having those pins pulled, and go towards -2.0 to save my front tires ...
      11-07-2012, 02:18 PM   #25
bdaddylo
bdaddylo's Avatar
Drives: 2017 F80 M3
0.5 sound excessive to me. I'm thinking more like 0.2 max. The pins are tiny and don't require any physical pulling to remove them.
_______________________
1991 E30 M3/Brilliantrot
2017 F80 M3/AW
      11-07-2012, 03:44 PM   #26
LotusBoy
Mhhh, I don't know. I think that pulling the pins allow more range in camber... Anybody with more info ?
      11-08-2012, 02:31 AM   #27
mm1
Drives: exE90 M3/ now1M
Very interested in your impressions of handling differences going form stock to modded camber. Is the rest of your suspension stock?
Sorry, was away for a while. Car is running KW v3, and the handling was improved, sterring seems to be more direct, car is pointier, if you know what I mean. Samll downside is a bit more tramlining, but I can live with it.
      11-08-2012, 08:26 AM   #28
MDORPHN
Drives: AW 1M
That's all that I picked up before I switched over to camber plates.
Neil
      11-08-2012, 12:17 PM   #29
Mahlzeit
Drives: 1M
Great - and ride comfort? Can you adjust to be as comfortable, or more comfortable than stock if you wanted?
      11-08-2012, 02:38 PM   #30
M3 Adjuster
Albania
7909
Yes... nearly everyone that posted in this thread..
Seriously.. there is a serious DISCONNECT in this thread between those who are opining based on previous or other BMW models vs those that are giving anecdotal factual evidence from experience on a 1M ....
      11-08-2012, 02:41 PM   #31
LotusBoy
Neil
Thanks Neil ! So we'll recall only 0.2 from removing the pins. Thanks for sharing ...
      11-08-2012, 02:45 PM   #32
Mahlzeit
Drives: 1M
Neil
Thanks Neil - so what was the max camber you ended up w/ before going to the plates?
~1.2 ish?
Your answer will likely end the main purpose of this thread.
      11-08-2012, 03:30 PM   #33
MDORPHN
Drives: AW 1M
~1.2 ish?
Yes, I believe it was 1.2 on one side and 1.3 on the other.
Neil
      11-11-2012, 06:19 AM   #34
LotusBoy
Hi guys ! In january, I'll go max camber on mine, including removal of the pins. I'm now at minus 1.2, and will report on this thread when the job is done. CU, Deejay.
      11-14-2012, 06:05 AM   #35
mm1
I have set it up a bit harder than the stock shocks, but it`s possible to have it just as comfy (or even more so) than the stock set up. And the ride is miles better than stock, especialy the rear of the car feels more planted and safer.
      11-10-2013, 09:02 AM   #36
jhonson3141
Drives: 1M
Originally Posted by int2str View Post
Almost -1 I think.
Around -1.25 with M3 control arms.
The 1m and m3 share the same suspension system and i have check that the control arm that they do share the same part number
was this M3 control arms relate to something else?
1addicts
