01-04-2020, 12:27 PM | #23 |
Rep 2,132
01-04-2020, 12:29 PM | #24 | |
Rep 2,132
01-04-2020, 12:30 PM | #25 | |
Rep 2,132
I don't know how to ping the internal IP of my router and google at the same time. edit: I did it by opening 2 different command prompts. When I ping my internal router, it's 3-4ms a lot but sometimes pver 30. When I ping Google, it's widely variable. Internal IP: Packets: Sent = 66, Received = 66, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 3ms, Maximum = 38ms, Average = 5ms Google.com Packets: Sent = 139, Received = 139, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 23ms, Maximum = 79ms, Average = 27ms |
01-04-2020, 02:42 PM | #26 | |
Rep 1,062
Drives: F15 xDrive50i M-sport
rtt min/avg/max/mdev = 0.128/0.202/0.251/0.046 ms...and to Google: rtt min/avg/max/mdev = 11.131/11.885/12.565/0.391 msFairly fast, fairly consistent. No lost packets when running them simultaneously.
2017 F15 xDrive50i M Sport | Superformance GT40 Roush 511 IR FE
01-04-2020, 04:19 PM | #27 |
Rep 440
Drives: 2013 335i xDrive
the ping time to your internal router should be almost instantaneous. Here is my wired ping results.
Here is my 2.4 GHz wireless ping results.
I'm not completely useless, I can be used as a bad example.
zx10guy5516.00 |
01-04-2020, 04:27 PM | #28 | |
Rep 1,062
Somehow I suspect your router may be flaky. Many SoHo routers are marginally adequate at slow internet speeds but become flaky when you push them into the bandwidth territory you're in.
zx10guy5516.00 |
01-04-2020, 05:54 PM | #29 | |
Rep 3,321
Per what pennsiveguy said, let's try plugging directly to the Ethernet hand off from the ONT. Hopefully AT&T isn't doing a MAC address registration which cable companies typically do. If so, you may have to spoof the MAC address of your router with your laptop/PC to get connectivity. ETA: I just did a continuous ping test over wireless and I am getting an average 4ms latency. I did a continuous ping test to google.com and have an average latency of 15ms. I'm doing this over my Comcast service at my primary home. |
jimbobiggens839.00 |
01-04-2020, 06:05 PM | #30 |
Rep 373
We see this a lot (I own an IT co). Usually it’s routers that do not have enough processing power, a lot of times it’s poor cabling (assuming the ISP is not having the same results upstream of your connection). First, we have to establish the issue is on wired connections. Assume all further suggestions are on wired only connections. Try a new certified Cat6 patch cable from your router to the modem (that would be store bought, not self made/crimped). Did you try the modem directly wired to a computer as suggested by others earlier? If your neighbor is having the same issue its likely the router upstream (ISP) is busy and may delay in icmp (ping) reply. Ping is not an ‘only’ tool. Its just one trouble shooting step, but a good one nonetheless.
01-04-2020, 06:53 PM | #31 | |
Rep 242
I read further replies and I need some more info to find out where the point of failure could be. First, if you connect your PC/laptop directly via a wire to your gateway provided by the ISP does this occur? It wasn't clear if you were connecting with a wired or wireless device, and/or how many intermediate devices there are in this setup. the ISP will tell you nothing is wrong if they can communicate over their advertised "speeds" to their gateway inside your home. Their responsibility ends there. So in summary, for this test, there should be no network, just the device provided by the utility to your testing machine via a wire, and the machine should have no programs open only a speedtest app (not in the browser as this adds a layer of complexity) or command prompt. Seth |
10-10-2020, 01:59 PM | #34 | |
Rep 2,132
10-11-2020, 08:48 AM | #35 | |
Rep 1,003
10-11-2020, 02:52 PM | #36 |
Rep 2,132
I have a Netgear r7800 and it’s perfect for my house. I have 20 devices connected and no issues on a 4000mbps connection.
10-12-2020, 01:55 AM | #37 | |
Rep 373
I don't have any recommendations. My own router has a 250Mbps limitation (even though it has a physical 1Gbps link) and my connection is 300. I don't have any issues. |
vreihen1620514.00 |
10-12-2020, 02:49 PM | #38 |
Rep 373
10-12-2020, 06:39 PM | #39 |
Rep 2,132
Yes, exactly the same setup. ATT service was just garbage.
Funny enough, ATT recently sent out several flyers saying they have "improved our service in your area." I guarantee a switch station, line, or something was screwed up and they finally got enough complaints. |
