Go Back   BMW E60 5-Series Forum | 5Post.com > BIMMERPOST Universal Forums > General BMW News and Cars Discussion
      10-23-2024, 08:50 AM   #353
RockCrusher
Drives: BMW 2023 ZB M2 6-speed
Originally Posted by F32Fleet View Post
There was talk years ago that NITRO contained a UCL which reduced enough friction to show up as tiny gain in TQ/HP.
Did not get the impression the gain in power/torque when Shell gasoline was tested was due to reduced friction.
While my info is premium gasoline can contain a bit more energy than regular gasoline the difference is not significant.
The primary benefit of premium gasoline over regular is -- for engines that require it due to higher compression/better cylinder filling (due to turbo/super charging) -- the better resistance to detonation so the engine controller can use more timing advance.
In the test both test vehicle engines were tuned to run best on premium gasoline.
The gain in power was I believe due to better combustion.
      10-23-2024, 09:12 AM   #354
RockCrusher
Originally Posted by Elderado82 View Post
All I know is that Shell gas here in NE is trash. I was regularly putting Shell in my M340i until it started having rough cold starts and wouldn't remote start anymore. I figured I'd try another gas to see if maybe I got a bad fill, so I went to Phillips 66, and the rough cold starts stopped. After a couple more tanks of Phillips, everything was good.
Being a BMW, I thought maybe I should go back to Shell, and well, what do you know, the car started running poorly again. Funny thing is, I even went to a different Shell station. So I went back to Phillips and had no problems.
About six months have passed, and now just about every Shell station here is turning into AMCO. Hmmm... has Shell turned into trash gas? This is just my experience here in NE with Shell. Has anyone else run into this?
Also, before you go on about spark plugs, fuel systems, and blah blah blah... I've already thought of those things, checked for cylinder issues and fuel system issues, and everything runs fine when not using Shell.
I haven't bothered to check my M2 owners manual but with other car brands there was kind of general recommendation in the fuel section that if the engine reacted unfavorably to a specific gasoline to switch brands.
So you did the right thing switching from Shell to Phillips 66.
      10-29-2024, 05:35 PM   #355
David70
Drives: 20 AM Vantage -13 Cadillac ATS
Originally Posted by FrankMstein View Post
Your preaching to the choir. I obviously know that some/all fuel contain some detergents and the difference between DI and PI engines. Your inability to talk straight between which is better vs it's all the same because its all from the same pipe talk vs TT has caused me to disregard your posts from here on out.
I have no idea what you are talking about. The part in bold is confusing.
Go ahead and point out anything I said that is wrong, that would be a good start.
2006 Z4M Coupe - ZHP knob, stubby antenna, clutch delay delete
      10-30-2024, 10:36 PM   #356
musa
musa's Avatar
Drives: F86, E92, E53, E39.
It's very easy for businesses to rip people off. Just add a couple of cents and pennies to a price and no one cares. Need to buy a new yacht, just add $ 0.50 to the price of gas per gallon to your thousands of customers and, bingo.
