F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Factory OEM F30 Wheels Offsets (18, 19, 20 inch) and Brake Sizes
proTUNING Freaks
      12-24-2022, 06:46 PM   #331
alohasurftoad
Drives: 440i gran coupe w/mppsk
[QUOTE=Luke330d;29670857 now my new wheels when i try to put them on they wont go on the hub properly because the wheels hitting the springs, do i just simply get some wheel spacers or?[/QUOTE]
spacers are the likely solution, however something else is amiss. based on the wheel specs you've shown us, interference should not be happening. what suspension do you have? what tire sizes are you using?
      02-13-2023, 10:38 AM   #332
kng_bishop
Drives: BMW F30
F30 Wheels
Hello! Do you know from where/how to download a PDF with all the standard wheels sizes OEM from BMW? I want to add my 18inches style 397 rims on the car`s identity card and I may need a document that says that these sizes are authorized by BMW.
Thank you
      04-28-2023, 12:02 PM   #333
Infinite0180
Drives: BMW 430i
Hey guys i think i already confirmed this but figured i would join here and make sure. Im buying a 2018 M sport 430i xdrive gran coupe with the brembo type large brakes up front. Its comes with the staggered 19s style number 704. A local guy is selling a mint set of square 18x8 et34 bmw style number 396 with winters on it. Im in buffalo and need something for next winter. Will these clear the brakes?
      08-22-2023, 07:51 AM   #334
NDA601551
Drives: 2014 BMW 328i
Great wheel tool!
https://www.tiktok.com/t/ZT8FfJh85/
      01-28-2024, 10:43 AM   #335
bruceb
bruceb's Avatar
Drives: 2016 320i w/ M sport adj susp
have a chance to grab some new sports contacts continental in this size will it be ok? 2016 320! with M Sport package and adjustable suspension: came stock with 235 up front and 255 rear. will this work? then I already have on order 235/45/18 for the fronts, but it's a shady deal I might have been scammed on those fronts and I ordered 4 because I'm ignorant not realizing she has a staggard setup. so I need to understand if I'm safe with a 245/40/18 square setup and also if 235/45/18 front and 240/45/18 rear.
Last edited by bruceb; 01-28-2024 at 01:15 PM.. Reason: auto correct needed correcting
Tags
f30 3 series wheel offset, f30 3 series wheel offsets, f30 328i wheel offset, f30 328i wheels offset, f30 328i wheels offsets, f30 335i wheel offset, f30 335i wheels offset, f30 335i wheels offsets, f30 offets, f30 offset, f30 wheel offset, f30 wheel offsets, f30 wheels offset, f30 wheels offsets, wheel offset f30, wheels offset f30, wheels offsets f30
f30post
