Go Back   BMW E60 5-Series Forum | 5Post.com > BIMMERPOST Universal Forums > General Automotive (non-BMW) Talk + Photos/Videos
      07-27-2023, 11:38 AM   #3235
Originally Posted by Car-Addicted View Post
Not sure we should be worried about climate change. Since we now know that the space aliens are here. They will either benevolently supply us with the solution or they will eat our faces. Either way problem solved.
'Climate change' is a made up name by rich greenie liberals with nothing better to do.
      07-27-2023, 11:39 AM   #3236
chad86tsi
chad86tsi's Avatar
1605
Drives: 2019 BMW M760i P60 Greyblack
Originally Posted by David70 View Post
Using our grid as it stands. U.S. is roughly 20% coal, it continues to drop and renewables and natural gas continue to go up.
Attachment 3238649
https://www.eia.gov/energyexplained/...-in-the-us.php
Not sure what the point is of the graph. Transport is only part of the problem? I agree. Our grid continues to get cleaner and I think as the grid gets cleaner it helps most of the other sectors.
A lot of that "renewables" is hydro, and hydro is being actively dismantled, not expanded.
The problem is that when the grid gets 10% cleaner, but we add 50% to the load to support EV's, that's not progress. Take a grid with 1G watt, and runs 40% carbon, and 60% everything else. That's 400MW of carbon, 600MW of everything else. Reduce carbon by 10% and we are at 300MW and 700WM. Multiply both by 1.5 and you now have 450WM of carbon and 1050MW of everything else. That's more net carbon consumption.
As it is, most EV's charge at night when supply is mostly coal and natural gas. Adding more of them isn't reducing carbon fuel consumption, even with the grid getting "cleaner". Time of use is never discussed, but it matters.
The fact that many states are seeing brownouts and curtailment on hot days is a good indicator that there isn't enough supply already. Until they invent nighttime solar or make the wind blow 24/7, and make that happen everywhere so we all have good access to that power, it's going to be a problem. Adequate Battery storage is a long ways off, and competes for the scarce and environmentally damaging resources that is making EV's possible.
M5Rick68643.00
PhaceN52177.50
kyriian959.50
      07-27-2023, 12:07 PM   #3237
chad86tsi
chad86tsi's Avatar
1605
Analysis: When do electric vehicles become cleaner than gasoline cars?
When they use clean energy.
2021 article U.S. was at 23% coal. EV still seems to win vs ICE when it comes to CO2 over the life of the vehicle, even when the grid is almost all coal.
Last night in California, arguably the green power capitol of the country, natural gas supply was 4 times more of the generation than renewables at 8:00 PM last night. 24.5Gw vs 6.1Gw. At 1:00 AM when some claim is the best time to charge, the ratio is nearly identical at 16.6/4.7.
Not all locations have solar or wind. Those CO2 over the lifespan formulas are useless when not taking into account time of day and actual location patterns. Absolutely garbage results really. No more useful than saying the average income in the US is $54K, so all policies and decisions about government taxes and subsequent resource allocation for every person in every location is calculated on that figure.
      07-27-2023, 12:18 PM   #3238
PhaceN52
PhaceN52's Avatar
178
Drives: '06 E90 N52B30 US spec
Thanks for saying that, it's a thing I'll never understand, hydro runs 24/7 with almost zero risk and it's full renewable, plus providing water reserve during summers for people and agriculture, yet still at least here, the guys complaining about cars smog and traffic while promoting 'green' evs are the same doing sit-ins screaming dumb slogans versus dams environmental flow mini plants construction (0.5/1 GW, small things), that use existing reservoirs and water that has to be provided to the valley river by law (and common sense)...
we're talking about a small turbine in a room like this one for every dam that has a normal hydro plant.. why not?!
yet huge spaces in the same zone for solar plants still rated at 0.5/1 gw that work only during the day are really good!
/offtopic
chad86tsi1605.00
M5Rick68643.00
      07-27-2023, 12:20 PM   #3239
chad86tsi
chad86tsi's Avatar
1605
The wooly mammoths should have been more careful with their CO2 production. If only they had the internet and media back then. Surely, they could have prevented the end of the ice age.
M5Rick68643.00
      07-27-2023, 12:46 PM   #3240
Car-Addicted
Car-Addicted's Avatar
Drives: 2020 BMW M4 CS
2020 BMW M4 CS  [9.91]
I thought this was very interesting technology
Koenigsegg Gemera's 600bhp camless engine works
By doing away with the camshaft and replacing it with a compact actuator above each tappet, the Freevalve system allows each valve to be individually controlled. They can be lifted as much or as little as the engine management dictates, for as long or as little as required, as early or as late in the cycle as required. Or not at all. And each can act differently from its neighbor.
https://www.topgear.com/car-news/fut...s-engine-works
lakefront640.50
M5Rick68643.00
      07-27-2023, 12:59 PM   #3241
gblansten
gblansten's Avatar
2492
Drives: 23 Tesla S Plaid
Originally Posted by Efthreeoh View Post
In summary, yes, we just need to burn fossil fuel better to lose less waste heat.
I discovered an engine startup in the UK at the beginning of this year and now for the life of me I can't recover the web page. But to summarize, its a different form of an internal combustion engine that is some 80% efficient and runs on nearly any type of combustible fuel. It would be a great design for a electrical generator in my wet-dream serial hybrid I discussed above. In fact the designer (company) is proving it in large generator use cases.
When one considers the loss of transporting electricity over the power grid and into the BEV storage battery, a serial hybrid can be is just as efficient with the right engine powering the generator. Fossil fuel just makes for better on-board energy storage. It's energy density is ideal when safety and refueling points of view are considered.
The modern EV drivetrain is excellent and I'd say the electric motor, which is as old as ICE, really has not much room to gain either. The EV advancement really is the battery energy density vs. cost and longevity quest and charging infrastructure. I just don't think the magic battery we've been hearing about for the past 20 years is going to materialize any time soon and put into practice under the umbrella of affordability. The answer to me is make electricity on board with a better ICE that's not burdened with a mechanical connection to the drive wheels.
The problem is Govenment is now involved with dictating the architecture, and any form of ICE is clearly off the table. That's what happens when humans think they can control the Earth's climate; they get all stupid and believe in themselves as God-like.
https://www.nextbigfuture.com/2023/0...batteries.html
I am really impressed with the manufacturing and efficiency gains of Tesla’s hairpin motor over the old winding method.
Efthreeoh19036.50
      07-27-2023, 02:04 PM   #3242
Belgium
70466
Drives: ///M3-E92-DCT Silverstone II
Don't know who the Alien is ...
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
M5Rick68643.00
KRS_SN14628.50
      07-27-2023, 06:37 PM   #3243
Ban on new gas and diesel cars in 2030 'will not happen'
https://www.dailymail.co.uk/news/art...ng-happen.html
KRS_SN14628.50
      07-27-2023, 07:01 PM   #3244
gblansten
gblansten's Avatar
2492
I thought they were getting ahead of themselves politically.
M5Rick68643.00
      07-27-2023, 07:15 PM   #3245
Car-Addicted
Amazing how the Brits have already forgotten that it was draconian EU rules that forced Brexit. Guess this time they are looking for a real butt whooping.
PhaceN52177.50
M5Rick68643.00
jmack548.50
KRS_SN14628.50
      07-28-2023, 05:13 AM   #3246
It's good that Brits,Hungary,Poland,Italy and some others now are challenging the authoritarian and unaccountable commands from the E. U bods, one presenting ongoing legal challenges
The whole shebang needs to be dis band ed and its not long before that day will come freeing Bel gium in particular from its over taxed tyranny.
      07-28-2023, 05:28 AM   #3247
The rubbing of flint to start fires so food could be cooked by cavemen/women was the start of it?
      07-28-2023, 06:03 AM   #3248
Serious doubts rolling in of the date in 7 years time for the crazy ban on gas cars, more news on this.
https://www.huffingtonpost.co.uk/ent...b053a700921e87
      07-28-2023, 06:32 AM   #3249
BGM-M3COMP
The Ben Shapiro of this place. I never lose! LOL
BGM-M3COMP's Avatar
2331
Drives: 12 plaids on order
So many cool car makers are going to put out amazing ev’s!!
This is great! That means they’re continuing on with this transition!!!!!
2035 on the move!!! lmaooooooooo
      07-28-2023, 07:11 AM   #3250
^ Can't read you BGM but I'm sure it's a knee jerk reaction
      07-28-2023, 07:41 AM   #3251
Murf the Surf
Murf the Surf's Avatar
21176
Drives: Porsche 993
I started to roll over his/her comments months ago. Nothing to add to the discussion.
M5Rick68643.00
MmmmmM22664.50
      07-28-2023, 07:49 AM   #3252
Car-Addicted
Troll or idiot, hard to tell, jury is still out.
      07-28-2023, 09:44 AM   #3253
G MONEY
Drives: 2017 458/ YAS m4
Yawn 🤡🤡
      07-28-2023, 09:52 AM   #3254
DrFerry
Field Marshal
DrFerry's Avatar
Drives: '08 E92 M3
2008 BMW M3  [5.25]
2015 BMW X5  [4.50]
Endurance Of Electric Vehicles Falters In Extreme Heat
Electric vehicles are known to perform sub-optimally in cold weather -- i.e. that's a loss of range and power. A new study has found similar adverse effects when EVs are subjected to scorching temperatures.
Auto blog Carscoops first reported that data science company Recurrent tested several EVs to "analyze the relationship between batteries and their range." Recurrent's data found that if temperatures rise over 100 degrees Fahrenheit, then the ranges of EVs diminish.
https://www.carscoops.com/2023/07/ex...tric-vehicles/
https://www.zerohedge.com/technology...s-extreme-heat
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/LUX H8 180/DCT Tune by BPM Sport/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
M5Rick68643.00
Llarry21400.00
      07-28-2023, 09:59 AM   #3255
DrFerry
Field Marshal
DrFerry's Avatar
Drives: '08 E92 M3
2008 BMW M3  [5.25]
2015 BMW X5  [4.50]
500 EVs Among The 3000 Cars On Burning Ship Off Dutch Coast
K Line, the operator of the car carrier ship involved in a serious North Sea fire casualty, has revealed there were 498 electric vehicles (EVs) on board.
The massive roll-on, roll-off ship ablaze off the Dutch coast is transporting 500 electric vehicles. The ship's total cargo is around 3,800 vehicles, some of which are BMWs and Mercedes.
The figure is far higher than first estimated and appears to raise the likelihood that a lithium-ion battery in an EV either caused the blaze on the ship (built 2013) or added to its severity.
According to K Line, there were 3,783 vehicles on board, all of them new, including the 498 EVs.
The consignment, loaded in Germany, was heading to the Far East via the Suez Canal.
I think one of the EV's battery packs spontaneously combusted...
https://www.tradewindsnews.com/casua...ay/2-1-1492734
https://www.zerohedge.com/markets/50...ip-dutch-coast
M5Rick68643.00
MmmmmM22664.50
Llarry21400.00
      07-28-2023, 10:01 AM   #3256
DrFerry
Field Marshal
DrFerry's Avatar
Drives: '08 E92 M3
2008 BMW M3  [5.25]
2015 BMW X5  [4.50]
Analysts Weigh In After Ford Pushes Back EV Production Timelines, Higher Costs
Ford shares are down hard early in the Friday session, after the automaker said its push into electric vehicles could lose it $4.5 billion this year. To put it briefly, it looks like the price war started by Elon Musk and Tesla in the world of EVs has done damage to the competition...
https://www.zerohedge.com/markets/an...s-higher-costs
M5Rick68643.00
M3WC3848.00
