05-31-2023, 09:39 AM | #2509 | |
Rep 709
Drives: 06 Black Sapphire Z4MR
Using my own Scion as a benchmark over 60k miles (which uses the same motor as a 2012-2017 Camry), I have spent $600 over 10 oil changes, $75 in 1 coolant swap at the shop, 1 Costco Battery for $100 So total, if we use the idea of removing common consumables like tires and brakes between EV and ICE, I have spent a total of $775 over 60k miles. I mean, more than 50% over estimate is not utter nonsense I guess.... My tires cost me $600, and that was Bridgestone RE980AS, not some cheapo tire. I won't know the cost of replacing brakes since I did my own, but 2 sets of front pads, 1 set of rear pads, 4 rotors is about $250 USD from Rockauto Total cost for me over 60k miles including tires: $775 + $600+250 = $1625 Let's compare to a Model 3, since we are talking here I will assume a Tesla will consume the same brakes 2 sets of the same grade to my pads in rockauto 'premium' grade, Powerstops is $440 USD (rough estimate after conversion, this is 2 sets of front pads, 1 set of rear pads, 4 rotors) 1 set of Bridgestone RE980AS+ in 235/45-18 from tirerack is $783 USD after rebate. Total cost for the Model 3: $1223 Even after adding brakes and tires, I am STILL under 2k 2K in maintainance over 60k miles likely applies more so to a BMW and had you use a BMW as a comparison then few would argue, but you are literally comparing to one of the most reliable cars with a low running cost.
Revolution of our Times
I will return to the track, one day. Last edited by kyriian; 05-31-2023 at 10:00 AM.. |
KRS_SN14194.50 |
05-31-2023, 09:46 AM | #2510 | |
Rep 2,527
I priced them both for 2023s off discount tire.
05-31-2023, 09:53 AM | #2511 | |
Rep 1,370
1993 Toyota Camry LE, owned from 1993 until 2012 when it was wrecked. 175,000 miles. All the scions are cheap crapboxes compared to that limo. It wasn't a huge amount of maintenance, but it wasn't as good as my 1992 Honda Civic CX, which is still on the road today, and the only things it needed were a water pump, and a drivers side interior handle. Please stop jumping to conclusions. You might sprain your ankle. Shawn |
05-31-2023, 10:00 AM | #2512 | |
Rep 1,370
The whole thing centered around calling $2k in 60,000 miles for the camry not valid. It is. AND, honestly, if you're going to keep the damn thing, a transmission oil drain and fill as well as brake fluid, and probably brake pads. And one coolant drain and flush. Brake pads age, and don't brake as well at five years. It's just part of owning the car. As well as insurance, and property tax. I'm not myopic on any of these. Not at all. But I CAN tell you that when maintained similar ways, the overall cost on an electric certainly SEEMS smaller when writing the checks, even when you DIY like I do (except tires and alignments, those machines are expensive). Shawn |
05-31-2023, 10:08 AM | #2513 | |
Rep 709
Cherry picking my statment like how you do right? Maths, YOUR very statement why EV has momentum is already discussed by everyone, 2k in maintainace, YOUR statement My maintainace is 1625 including tires, not 2k Model 3, including the same grade and consumption rate in brakes and tires, is at best $400 bucks cheaper over 60k miles, I will state AGAIN, never have been pro ICE or pro EV, its just a fking car and if the maths work for you and anyone else great, good for you. But throwing random numbers like this is utter nonsense because its not true as Efthreeoh has already pointed out You also seem to be the only one who add the same consumable costs to your equation, considering most EV uses tires faster, uses brakes faster (just heavier weight) so removing these two factors BENEFITS EV.
I will return to the track, one day. Last edited by kyriian; 05-31-2023 at 10:14 AM.. |
05-31-2023, 10:15 AM | #2514 |
Rep 1,952
In reality the only fluid EVs don't use is engine oil unless the motors are direct drive. Coolant, brake fluid, transmission fluid, washer fluid all present. And of course fuel but that isn't exactly a wear item... Wear and tear should reflect a heavier vehicle (minus brake pads thanks to regen). Last edited by freakystyly; 05-31-2023 at 10:20 AM.. |
05-31-2023, 10:54 AM | #2515 | |
Rep 1,952
It's shocking how many people in the general public never look at their tires until someone tells them to... going in for service or gov. inspection is often a benefit beyond the service expected. |
05-31-2023, 11:03 AM | #2516 |
The Ben Shapiro of this place. I never lose! LOL
2330
Rep 3,021
Drives: 12 plaids on order
2028 will really be the start of the party!
2035 on the move!!! lmaooooooooo
05-31-2023, 12:43 PM | #2517 | |
Rep 1,370
Shawn |
05-31-2023, 01:24 PM | #2518 |
Rep 1,952
I'll admit most of my EV knowledge comes from quick google searches.
As far as I know there's at least one EV make with a transmission. And the open differentials on Teslas probably shouldn't be dry, are they? They're basically e-diffs that every other "performance" car maker use. Real mechanical LSDs are optional and it sounds like they don't come with them from factory, maybe the plaids. |
05-31-2023, 02:57 PM | #2519 |
Rep 5,383
brother in law has a toyota hilux..he took me off roading in a mountainous area. The tyre climbed over one particular rectangular piece of rock the size of a Coffin and the chassis landed on the rock with an almighty thud...
He carried on and got the other wheels over the Rock and then stopped the car with a worried expression and stepped out and came back and told me ..."don't worry that rock is ok" .. 6 yrs on its had zero problems. |
StradaRedlands5907.50 M5Rick66289.00 |
05-31-2023, 02:59 PM | #2520 |
2330
Rep 3,021
I love when regen puts energy back into the car! Can’t do that with ice!
05-31-2023, 03:27 PM | #2521 | |
Rep 1,370
Shawn |
05-31-2023, 06:41 PM | #2522 | |
Rep 1,662
05-31-2023, 08:13 PM | #2523 | |
Rep 3,602
Current: 2018 Camaro SS 1LE, 2023 Colorado ZR2. Former: BMW 428i Gran Coupe.
06-01-2023, 07:39 AM | #2524 |
2330
Rep 3,021
Time to jive in 2035!
06-01-2023, 10:41 AM | #2525 | |
Rep 21,444
https://www.dailymail.co.uk/news/art...ed-policy.html |
06-01-2023, 05:10 PM | #2526 | |
Rep 598
06-02-2023, 01:29 PM | #2527 | |
Rep 21,444
Next should be the end for the hitlerite 2030 stop date for fuel cars and a return for people to choose whatever car they want, petrol or EV. |
06-03-2023, 05:54 AM | #2528 |
2330
Rep 3,021
06-03-2023, 10:03 AM | #2529 | |
Rep 2,377
Drives: 2020 BMW M4 CS
06-03-2023, 11:48 AM | #2530 | |
Rep 7,146
Drives: 2022 DG/BLk xDrive M4C Wk 34
It was about $150 more, last month, since I went to Reno, and drove out to the south bay area, 3 weekends in a row. A round trip to the south bay, is about 3/4 of a tank, round trip. Reno and back is a tank.
2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou |
AlpineBoost3930.50 |
