BMW 3-Series (E90 E92) Forum
Starter help e90
05-08-2024, 07:17 PM | #1 |
Rep 7
Starter help e90
Yo so I just had a question about my car. Car has good battery alternator is good fuses are good but no start no crank just a click. Was wondering if I should change ground strap first before diving into the starter 2010 328
05-08-2024, 08:03 PM | #2 |
Rep 3,928
Drives: 330i, 135i
Can you read codes? Have you ever replaced your starter? If not most likely you nee a new starter. I replaced mine on my 06 E90. Lasted about 10yrs.
Dtheking879.00 |
05-08-2024, 09:27 PM | #3 |
Rep 7
Yea I just have a code for starter actuator. I read a lot that 99% of times nothing happens when your actual starter is bad and only the ground strap is bad when you get a click. But either way went and got a brand new starter just to be safe and some universal ground strap from my local parts city hopefully it works lol
05-08-2024, 09:31 PM | #4 |
Rep 7
And no I have never replaced started. I’ve only owned car for line 3 months and other then the existing problems I knew when I bought it this is the only new one.
StradaRedlands5033.50 |
05-09-2024, 12:25 PM | #5 |
Rep 140
Somebody posted that you can check whether ground strap is bad by using jumper cable from ground to engine, providing alternate path for ground. You might look into that first. Good luck
The Nightman1093.00 Daaaaaaaan92.50 |
05-09-2024, 02:15 PM | #6 |
Rep 1,232
When a starter clicks it could be a few things.
1. Starter itself is engaging but just doesn't have the power to turn the engine. 2. Bad power/grounds 3. Engine is seized and starter will never be able to turn the engine. Have you attempted to turn the crank by hand with a large breaker bar just to make sure the engine isn't locked up? |
Mike K332.00 |
05-09-2024, 03:44 PM | #7 |
Rep 7
I really don’t think my engine seized. I don’t have any engine issues not even a CEL. And before it just stopped starting completely , it would take a couple button presses to get it to start and that was for 2-3 days before it completely stopped starting
05-09-2024, 04:01 PM | #8 |
Rep 7
Not having the power to crank is most likely a bad ground strap tho or something right ? Alts good battery’s good fuses are good and only code I get is a starter actuator code
05-09-2024, 07:08 PM | #9 |
Rep 3,088
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.25]
2009 BMW 328i Touri ... [8.00] 2013 BMW X5 35i [7.80] 2011 BMW 528i [8.70] 2006 Mazda3 [5.50] |
Yeah, connect engine to the frame with a jumper cable (just one color). Replicates the path of the ground strap. Grab one of the oil filter housing bolts, and connect over to the ground bar on the passenger side.
Mike K332.00 |
05-09-2024, 08:05 PM | #10 |
Rep 7
It was starter. Changed it out fired right up. To my surprise too cause when I was down there I found a massive ground strap that was corroded right in the middle so bad that it broke. But I had absolutely no way to get to parts city to buy a replacement but definitely will be getting it replaced tomorrow!
05-14-2024, 05:32 PM | #11 | |
Rep 163
Rust belt life. Check your ground straps fellow rust belt dwellers! |
05-16-2024, 09:04 AM | #12 |
Rep 7
Not sure how to reply to your comment but you could be right about the ground strap. I’m gunna grab one tomorrow I’m pretty sure it’s the engine to body ground
