04-13-2021, 01:34 PM | #1 |
Rep 7,457
1x vs 2x for road bike
Hi All,
I'm looking at grabbing a casual road bike (as opposed to my two dedicated roadies) for quick jaunts or local cruising. Basically I want a bike that I can jump on wearing shorts, tee shirt, and sandals and pedal around the 'hood for 30 minutes or so. Or maybe haul up to the local bike trail for an easy ride with friends. I originally wanted a Trek FX 4 Disc with a 1x11 drive train, but it's backordered and the LBS says I'll be lucky to see it by August if ever. However, they have an FX 3 Disc in my size in stock that I could buy now. The two bikes are essentially identical except for the drive trains. The FX 4 has a 42T sprocket up front and an 11x51 (11-speed) in the rear. The FX 3 has a 46/30 up front and an 11x36 (9-speed) in the rear. My only reason for the 1x was the simplicity of it plus the somewhat cleaner appearance. But I'm not sure those reasons outweigh the issue of waiting months or longer for the 1x. Any thoughts on 1x11 as opposed to a standard 2x9? I have one riding friend who has a 1x11 gravel rig and hates it. He thinks I should go with the 2x9. I'm starting to lean that way.
04-13-2021, 02:10 PM | #2 |
Rep 469
The gear parts of the 1x11 are better than those of the 2x9 so I would go for the 1x11. Also since it will just be a casual bike it will be simpler to self service.
However if you could get 2x11 Deore or better gears I'd go with that any day.
DD: F48 X1 xDrive25i '20 - https://f48.bimmerpost.com/forums/sh....php?t=1703083
For fun: F22 M240i '19 - https://www.2addicts.com/forums/show....php?t=1644646 Previous BMW: Fully loaded F30, 335i https://f30.bimmerpost.com/forums/sh....php?t=1681247 |
04-13-2021, 02:34 PM | #3 |
Rep 621
Obviously you're not going to wait months for a bike. A 2x9 is fine for your use regardless if the drive group set is a tier higher. Also, if you mean local trail as in a rail trail then OK but if you mean a cross country trail you'll probably want to move into one of their lower tier mountain bikes instead. Something like a Marlin 8.
04-13-2021, 02:45 PM | #4 | ||
Rep 7,457
04-13-2021, 07:51 PM | #5 |
Rep 2,345
Drives: 9Y0 Cayenne S
Do you have something to ride now? Wait for the 1x. If not, get the 2x.
04-13-2021, 09:07 PM | #6 |
Rep 7,457
I have my dedicated road bikes, but they're not the same animal. I can't just jump on them and go. Special shoes (clipless pedals), usual riding gear, etc. My big fear is that August will come and go and I still won't have a simple cruising bike. And the dealer said he isn't even sure Trek is making the 1x version any longer. I'm thinking I'll grab the 2x and if the 1x suddenly becomes available for immediate delivery, I can always sell the 2x if it isn't working out.
chassis6690.50 |
04-14-2021, 06:08 PM | #8 |
Rep 2,345
Congrats. Are you a dedicated Trek person? Or did you consider Specialized, Cannondale or other brands? Why/why not?
