06-10-2024, 10:46 PM | #24 | |
Rep 1,160
I quickly leaf blower as well to keep water off my garage floor. |
arsunic49.50 |
06-10-2024, 11:31 PM | #25 | |
Rep 104
A pre-rinse could allow scratches on the paint by the dirt, grim, pollen or mud. A pre-rinse will allow grim/dirt to rub into the finish. As a pre-wash with a snow cannon will encapsulate these contaminants (grim etc) and lift it away the surface. If your car is filthy, a soap with a low pH will work best; or like you mention Bilt Hamber or CarPro Lift. But, I wouldn’t use these soaps on my car with ceramic coating. It’s a simple car wash: Foam, Rinse, Foam, contact wash and rinse. Dry with a leaf blower.
2021 BMW X5 M50i Tanzanite Blue II Metallic
rmedina138.50 |
06-11-2024, 02:02 AM | #26 | ||
Rep 386
Bilt Hamber is supposed to be safe on all coatings and claims to offer real touch-less” cleaning power compared to the other offerings. We shall see once I get to try it.
2013 E92 M3 |Space Grey | Fox Red | Manual
1999 E36 M3 |Hellrot Red | Black | Manual IG: @moya_M3 |
06-11-2024, 10:38 AM | #27 |
Rep 1,174
I typically foam before pre rinsing.
When its really dirty i use car pro lift for max cleaning power (remove as much as i can) and the water from the pre rinse can dilute that mixture. then i foam again and do contact wash for regular maintenance washes, i can get away with just foaming on and letting it dwell and then power wash off...I typically have a good coating on my car and its garaged, so unless its super dirty i don't do a contact wash... |
arsunic49.50 |
06-11-2024, 11:47 AM | #28 | |
Rep 1,160
Hagasan41326.00 |
06-11-2024, 06:13 PM | #29 |
Rep 386
Ha! I hear ya life gets in the way of car washing. LOL. Wet coat and Hydro 2 are in my arsenal for sure. They have their place and are great for the daily driver or if you’re short on time.
06-11-2024, 07:38 PM | #30 | |
Rep 1,160
Past 2 years or so, I 've mostly just prefoam with Bilt Hamber Auto Foam then just rinse with DI water. I'll full wash once a month or two but otherwise, the Auto Foam gets me 80% there with 10% of the work. |
06-13-2024, 04:00 PM | #31 |
Rep 1,174
06-13-2024, 04:08 PM | #32 |
Rep 1,160
06-14-2024, 02:12 PM | #33 | |
Rep 1,174
foaming and rinsing to get the same results...with the hydro2 foam... Wet coat is also an awesome product, but the foam provides better more even coverage as well |
TboneS541149.00 |
06-14-2024, 03:36 PM | #34 |
YNWA
1149
Rep 875
That's my gripe with water contact sio2 sprays (hydro2, wet coat, supercharger) - way too much spraying for an entire car, and probably mostly used for wheels/calipers/exhuast pipes or other odd shaped things. Foaming the car with hydro2 sounds good.
/// 2004 Silvergrey M3 · Coupe · 6MT · Slicktop · zero options
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54 |
07-23-2024, 03:46 PM | #35 |
I like to eat eat eat apples and bananas
23
Rep 23
Does anyone else wash IN the garage? I always do and the neighbors think I'm a nut. I want to keep the hot sun from drying the soap/water prematurely and I want to keep the wind from blowing dust on to the wet car.
07-24-2024, 04:19 AM | #36 |
Rep 97
If I had a garage, I would wash it in the garage! Keeping it out of direct sun to reduce the soap from drying on the paint is important. I try to wash first thing in the morning or even on overcast days trying to reduce the hottest part of the day and direct sun when possible.
07-24-2024, 03:12 PM | #37 |
Rep 187
I wash my car at 7am to avoid the sun, but I pull the car into the drive way. I dry it in the garage though.
90% of the time I rinse, foam and hand wash. Every once in a while I’ll just rinse and foam. Quick drying towel for large panels and leaf blower to get everything else. On average once a week, mid week, I’ll do a quick detail of the car with a good detail spray. A good ceramic coat makes a world of difference in my anxiety- I wouldn’t do a mid week cleaning without it. I clean my windshield probably 4 days a week. I intend to get a DI setup, just haven’t yet. |
07-28-2024, 08:48 PM | #38 | |
Rep 545
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
lopeydeath159.50 |
07-28-2024, 10:33 PM | #39 | |
Rep 187
I’m not sure how much water I use to wash my car, but I imagine 2K gallons would last quite a while. |
07-29-2024, 02:17 PM | #40 | |
Rep 545
I rinse, foam, wash, rinse, dry. If the car is really dirty I will rinse, foam, let it dwell, rinse, foam, wash, dry. I have to microfiber sponges and will switch when I go from the less dirty areas to the lower areas. I also have a boards hair brush I use for really bad spots. Like baked on bugs. Worst case I treat the area directly with undiluted car wash. Let it sit, wet it again, and then agitate with a small boards hair sponge and rinse. The car has the front full front and lower rear PPF and the entire car ceramic coated. So far nothing sticks. |
lopeydeath159.50 |
07-29-2024, 03:22 PM | #41 | |
Rep 187
Ok, so for some reason I thought the salt was the medium - so that was my mistake. I really want soft water - there’s a good chance I get stationed in Bahrain next year so given how absurdly hot it is I’ll definitely need soft water as I won’t be able to beat the speed with which water dries no matter how early I get up. |
Dan B456.00 |
08-02-2024, 10:15 PM | #43 | |
Rep 253
08-04-2024, 06:22 AM | #44 |
Rep 196
I use Bilt Hamber touchless before I wash the car or even rinse the car. You can see the foam literally pull the top layer of dirt off when you let it dwell for 5 min. After I rinse the touchless off, I foam it back up with Koch Chemie and do a two bucket wash. The combo works great.
arsunic49.50 |
