Go Back   BMW E60 5-Series Forum | 5Post.com > BMW 5-Series (E60) Forums (2004 - 2009) > General 5-series and M5 (E60) Forum
      05-31-2012, 03:27 PM   #1
edeve13
Drives: 525i 2008
528i 2008 change xenon to halogen
hi, im in front accident with my car and when verify the cost of the xenon heads is too high. my question is if i can change the oem xenon heads to halogen.
      05-31-2012, 08:52 PM   #2
Shane550X
Shane550X's Avatar
Drives: '18 M550i xDrive, '13 VW CC,
Pretty sure they can be replace with halogens as long as the electrical box is upgraded or downgraded by the load on the box, and you want both of them to be replaced so it will most likely work!
Shane
      06-01-2012, 03:03 PM   #3
edeve13
Drives: 525i 2008
are you sure on this...only that i need is an upgrade ...
      06-02-2012, 10:11 AM   #4
josebmw
Drives: 08 335i sedan
headlamps.
Hi, yes you can swap the xenon headlamps for the regular ones, the only problem is fact that the xenon headlamps have one module for the adaptive headlamps, the regular ones does not have this option and for that reason you will have the message on the dash for headlamp malfunction as well as the led on the light switch flashing.
