05-09-2024, 10:14 AM | #1 |
Rep 16
Drives: 2020 M4 Comp LeMans Blue
F82/S55 engine ticking
Looking for help to diagnose a ticking/clipping noise in exeperiencing on the car. Usually happens after driving the car for a little bit and persists when the car is warmed up as well. The speed of the ticking/tapping increases as the RPMs go higher and can be mostly heard around to 1-2.5k RPMs. I’ve heard this could be exhaust camshaft that needs to be retorqued but looking for more confirmation. Thanks
https://youtube.com/shorts/dPYD3-vM6...sMp-CCzTF3aT2t |
05-09-2024, 12:33 PM | #2 |
Rep 650
Mine had a similar noise but not as pronounced.
While getting crank hub done I had exhaust cam alignment done and it’s sounds fine now(apart from belt chirping sound but that is almost gone now that I change belt tensioner) |
05-09-2024, 01:52 PM | #3 |
Rep 16
That’s how I’m hoping I can do, I am thinking of getting CH done in the next 2 months where I can get that fixed at the same time. Hoping that’s the fix for this, cause I just got the car less than 2 months ago with only 24k miles.
05-09-2024, 03:54 PM | #4 | |
Rep 650
With hind sight I prob would have changed to new valve cover given I got the crank hub and tune done at 82k km |
05-09-2024, 10:57 PM | #5 |
Rep 59
Just noticed this issue today. Not as bad as yours, but I also suspect not having the engine cover is what's causing me to notice it just now. I wonder if it's an urgent issue that needs to be addressed ASAP or not
05-10-2024, 07:35 PM | #8 | |
Rep 16
https://youtube.com/shorts/01s1fcZjt...5nYKt_ntHE7tyf |
05-10-2024, 07:37 PM | #9 |
Rep 16
I sent the video to one of my local mechanic they think it’s either cam slap or rod bearing slap. Will need to start a tear down to find the source. I have an appointment Monday to drop it off. I’m in complete disbelief this car is untuned with 26k miles with only 1 owner before and already having problems.
05-11-2024, 06:57 AM | #10 |
Rep 1,322
Yeah, to my ears the sound at pure idle doesn't sound very off to what seems like the normal S55 sound, but when you rev it, that "looser" rattle-like sound definitely seems abnormal. Good luck with the diagnosis/fix, keep us posted.
05-19-2024, 09:25 PM | #11 |
Slow Guy
11
Rep 39
Mines been doing that for the last 40k km's, goes away after it warms up a little bit. Stage 2 and I drive the piss out of it. Like another user said you can get the exhaust camshaft bolts (something like that) replaced to get rid of the noise.
Yesterday, 09:51 PM | #12 |
Rep 16
Final update: cars back from the shop, they replaced all the cam ledge bolts and torqued to spec. Sounds is all gone and no other issues! Glad to have my car back finally after 2 weeks
