Go Back   BMW E60 5-Series Forum | 5Post.com > BMW 5-Series (E60) Forums (2004 - 2009) > General 5-series (E60) Forum
      12-14-2012, 05:01 AM   #1
Sergio
Drives: BMW 323i 330xi MDX
528xi better than 535xi for maintenance
Shopping for a 5 series and my private BMW mechanic told me to stay away from 535xi for the following reason.
1 turbo goes big job $$$
2 or if injectors or
3 high pressure fuel pump goes its big bucks
He works full time at Bmw and has seen the common problems that occur
Your thoughts??
Thanks
Sergio
Sergio is offline   Canada
      12-14-2012, 10:03 AM   #2
WJGreer
WJGreer's Avatar
Drives: 2005 E60 545 Sport
Your thoughts??
Thanks
Sergio
Well, all three of those are more or less the same problem, or at least forced induction problems generally. What your mechanic is telling you is that the 535's engine is more complex than the 528's, which is self-evident since the former is a turbocharged equivalent of the latter, and in the case of the 528, a turbocharger that does not exist will not incur maintenance expenses.
But, then again, the 535 is a whole different car than the 528 performance wise. So - you have to prioritize according to what you want in your car.
Setting aside the HPFP issues that the N54 engine had, I don't think the 535s have had more trouble with the induction system than any similar product on the market.
-Will
2005 545i Sport | 2001 X5 3.0 Sport (Retired)
WJGreer is offline   Reply With Quote
      12-14-2012, 09:02 PM   #3
Sergio
I'm looking for a good BMW 5 series, with reasonable costs to maintain.
I don;t have access to BMW records, but it would be interesting to know the costs to maintain a 535xi vs a 528xi, if sold at same time to same type of driver.
Thanks for reply!
Sergio
      12-14-2012, 09:57 PM   #4
mweine
Work Hard! Play Harder!!
mweine's Avatar
Drives: BMW 1M
1989 BMW M3  [0.00]
Send a message via MSN to mweine Send a message via Yahoo to mweine Send a message via Skype™ to mweine
I had an E60 528xi produced May 2008 and now drive an E60 535xi produced Sept 2008. Electrically, I find the 535 to be more reliable? As for the engine, the 528 never gave me any issues, while the 535 has had several issues. The engine never failed, however it has been missing between 2000 and 3000 RPMs and no mechanic has been able to fix the issue. Every now and then the chk engine light goes on and from that, BMW changes another engine part on warranty (Vanos, fuel injectors, spark plugs, de carbonization, now the coils). The car has 54k kms.
However, even with these issues, I would never go back to the 528, because the 535 is significantly more fun to drive. The N54 has so much more power than the M20 and it is so easy to program even more power from the engine. With the Dinan Stage 2 SW, the car is a rocket. The 528 is relatively boring to drive.
mweine is offline   Canada
      12-15-2012, 09:24 PM   #5
Sergio
Thanks for feedback!!! I would probably enjoy the 535 ride over a 528 too.
Since I will be buying a used 5 and the warranty will probably be finished, this is the part I need to be careful. You are very fortunate to have all these changes at dealer at manufactures cost
I wonder how does are doing with more warranty
Take care
Sergio
Forum Jump
