Go Back   BMW E60 5-Series Forum | 5Post.com > BIMMERPOST Universal Forums > General Automotive (non-BMW) Talk + Photos/Videos
      03-20-2012, 09:58 PM   #1
EFI Logics
EFI Logics's Avatar
Drives: '08 BMW 135i, 08 535Xi
3.3RS Dyno Run
I thought I would share this with you guys as I truly love this car and this video. This is Jack's (Shop Foreman/Lead Fabricator at EFI Logics) Subaru 3.3RS. It's a 6 cylinder EG33 NA motor sourced from a Subaru SVX. He built this monster from the ground up and uses it to compete in NASA ST-2 class. Enjoy...
-Josh
      03-23-2012, 08:15 PM   #2
coco_m3
coco_m3's Avatar
Drives: Supercharged E90 M3
2008 BMW M3  [0.00]
2010 BMW E90 335i  [0.00]
DAYUM..
      03-24-2012, 08:40 AM   #3
EFI Logics
EFI Logics's Avatar
Originally Posted by silverbullet135i View Post
DAYUM..
      03-24-2012, 11:44 AM   #4
wisesoul
Savoir Faire
wisesoul's Avatar
Philippines
74
Drives: 2013 BMW M5
Holy shiiiiit that sounds awesome!!
Current: Alpine White F10 M5|H&R springs|12mm/10mm spacers|Eisenmann Race
Sold:Imola Yellow RS4-KW V3|MTM 10mm spacers|Hotchkis rear sway bar|APR Stage 1|Milltek Catless|RNS-E|Euro RS4 Flat bottom Steering Wheel
Sold:E46 323i
      03-26-2012, 04:28 AM   #5
san~man
Tired
san~man's Avatar
131
Drives: BMW-less
So what did it make?
BMW-less
      03-26-2012, 07:57 AM   #6
EFI Logics
EFI Logics's Avatar
Here are the specs:
"2000 Subaru RS
BBS Brakes all around
JIC suspension
Custom Rear sway bar
Custom Front Sway Bar
Cage by Bob the Fabricator
Custom Dash with Autometer gauges
Engine / Management:
EG33 SVX Flat 6
Custom Ported heads
Manley Rods
Cometic Head gaskets
ARP Head studs
Custom Web cams
Supertec valvetrain w/ BMW Solid buckets
Modified Cam gears
Custom JE Hich Compression pistons - All machine work done by Larry's Automotive in Stonington, CT.
Stock Intake Manifold
Custom 8qt Baffled road race pan (Bob the Fabricator)
Meziere Electric Waterpump
Custom 1 3/4 Headers (Bob The Fabricator)
Custom Motor and Tranny mounts
Custom Air box (Bob the Fabricator)
Custom MSD Ignition
Balanced and Blueprinted STIi Injectors by Deatschwerks
Autronic SMC Engine Management tuned by EFI Logics
Autronic CDI box
Custom 5 speed gear box W/ RA Gear set and Cusco Tarmac Center diff from Fizz Autosports
There is probably more we are missing, but that is the most of it. The car was tuned today, on our Mustang Dyno, and produced a very impressive 320whp and 276wtq @ 8200rpm, SAE corrected. Dyno Graph (we are working on the bug with it going off the chart)."
-Josh
Tags
3.3rs, efi logics
