      11-25-2012, 08:33 AM   #1
kswan23
Drives: 535i
FM radio problems. Weird
My 530i's idrive radio is very staticky and cuts in and out bad. Almost like there is no antenna (at least that's what it sounds like). The cd sounds perfect. It's only on the radio. Is it possible that the antenna plug in the back of the idrive worked itself loose and is coming out or is it a more serious software problem?
Someone mentioned it could be the diversity antenna. Is there a way I can test this before replacing it?
      11-25-2012, 07:26 PM   #2
kswan23
Drives: 535i
Bump
      12-04-2012, 06:40 PM   #3
turbonewb
Drives: 2004 530I
2004 BMW 530I  [0.00]
You might have a bad TCU unit. Here is a link related to your problem...http://www.bimmerfest.com/forums/sho...d.php?t=327575
Good luck!
      01-05-2013, 11:20 PM   #4
mister5kevin
mister5kevin's Avatar
Drives: 2010 BMW 535xi
Did you replace your angel eyes?
When I replaced mine, my FM went fuzzy : (
      01-06-2013, 08:29 AM   #5
darkrider
Drives: 2010 E60 535i
+1, this seems to be a common problem with some AEs.
      01-07-2013, 12:40 PM   #6
Ace333
Ace333's Avatar
Drives: 2012 535XI
2008 528XI  [0.00]
What about the Angel Eyes would have an effect on the FM single reception? I have replaced mine without issue.
      01-28-2013, 07:47 PM   #7
mister5kevin
I brought some cheap ones from eBay and caused FM static. So I returned them and brought LUX. No static.
Not sure y it caused static but it does happen to some BMW models
2010 E60 535xi Black exterior/Brown interior
Mods: black kidney grills, LUX angel eyes, SMD interior lights
