01-24-2013, 03:10 PM | #1 |
211
Rep 1,385
.:Trinity Autosport:. RDSport Sway Bars for E60/E61/xi NON M
Hi Guys,
RDSport FINALLY released the front and rear sway bars for NON M E60/E61/xi models! The price is $579 shipped! Description RDSport's lightweight hollow sway bars weigh a scant 7 lbs for the front bar and only 4 lbs for the rear, and are adjustable to be between 16 and 33% stiffer than the factory sway bars. These sway bars not only increase the overall spring rate to reduce body roll at any setting, but are also adjustable for the rate of spring rate increase, and will yield much more aggressive handling response. By enabling the driver to change the rate of increase of the swaybar stiffness, RDSport swaybars will help tune out understeer on initial turn in. The 30.2 mm, hollow front bar and 22.2 mm hollow rear bar are designed specifically for the 5 Series Xi models, and improve the handling of BMW's superlative xDrive technology. Each bar is powder-coated in RDSport's signature green color for durability and include new, stiffer, urethane bushings with lubricant-retaining grooves, new die-cast front bushing brackets, and a proprietary waterproof Teflon-based lube. · 30.2mm Front Bar Thickness · 22.2mm Rear Bar Thickness · 25 Position Adjustable · Increased Stiffness and Handling · Replacement Urethane Bushings · New die-cast front Bushing Brackets · Lightweight Hollow Construction · RD Green Powder Coat Finish ***CARS WITH DYNAMIC DRIVE THE SWAY BARS WILL NOT FIT*** |
