12-26-2015, 02:17 PM | #1 |
Rep 4
Phantom Overheat
Last night I was just on the interstate and my 525i (2006) displayed an overheat message - yellow then immediately to red. I was able to hop off at an exit which was a few hundred yards from where the warning was posted. I turned the car off and restarted and everything had cleared. System check said all was well. I drove the car back to the house, the long way, and did not experience another problem.
Details - recently I had replaced a failed hose from thermostat. I had drained the coolant and re-filled with Genuine BMW coolant. Once that was done I ran the process to bleed the air and everything seemed normal. A couple of days back I decided to run the process to bleed the air again. Doing so I inserted a funnel with some premixed coolant. Once completed the reservoir was completely filled and I replaced my cap until it clicked into place. I didnt drive the car right away as I had a lot of my plate and typically drive another vehicle most days. One other thing I noticed is that after the hose replacement the electric fan will run full speed and slowdown numerous times when the car is first started. Thoughts? |
12-26-2015, 10:29 PM | #2 | |
Rep 1,362
01-04-2016, 09:16 AM | #3 |
Rep 4
Replacing the water pump and thermostat would certainly fix the issue, but how can I be sure the problem was either? As I mentioned once stopped and turned off and immediately restarted the engine the code had cleared. If it were over temp then I should have been warned immediately since the brief off and on would not provide time for the engine to cool.
01-04-2016, 03:42 PM | #4 | |
Rep 1,362
I was driving on the highway when my problem started my car went into limp mode, open my hood coolant everywhere but don't know where i came from. So when i restarted the car everything was fine again, since i lost coolant i drove the the nearest autozone to buy some. After i replace the water pump and thermo never happen to me again. |
01-05-2016, 06:16 AM | #5 |
Rep 4
My coolant level was the same with nothing showing under the hood. Fan runs/stops/runs when the car is started. I am thinking it may be the sensor.
I havent had the car out for a few days. With the current break from the rain I'll get it out and see if the error recurs. Thanks |
01-08-2016, 05:26 PM | #6 | |
Rep 1,362
Tags |
coolant, fan, overheat |
