      11-25-2021, 02:49 PM   #1
Jazerramos
Drives: Bmw 528i 2008
Cat back for 528i?
In YOUR opinion, what's the best cat back exhaust system I should get for a bit better performance and air flow for bmw 528i 2008??
I currently got muffler delete but would like to move onto cat backs soon.
      11-25-2021, 10:07 PM   #2
e91Owner
e91Owner
Drives: 2011 e91 & 2010 e60
You might want to ask on the e90 mods forum. It'll be a different part number, but the same engine and the e60 board is basically dead.
      11-25-2021, 10:08 PM   #3
Jazerramos
Thanks bro
      11-25-2021, 11:21 PM   #4
JayArras
Casual Fanatic
32
Drives: '07 530xi
Don't expect much improvement in a base-level engine.
2007 530xi, Black Metallic Sapphire, 6 speed manual, Sport package, Cold Weather Package, Premium Package, Premium Sound Package, Sirius Satellite Radio, MTech front bumper, Replica Style 166 wheels
      12-31-2021, 02:09 AM   #5
mpathic
Drives: Z4 MCoupe,3.0Si R,E61 535xiT
Put on a 535i or 550i muffler, and remove your resonator. Direct bolt-in to the same mounting points as you have already. Use 3" pipe from a y-connector behind the cats back to the muffler, leaving out the resonator. The resonator, and the smaller pipe diameter behind it, is the real flow restriction.
Muffler delete isn't effective if you leave the stock resonator and exiting 69mm pipe in place.
Or, put a y-connector behind the cats, and then a Flowmaster 3" diameter resonator under the middle of the car behind the cross-brace of the driveshaft tunnel where the original heavy resonator was, then 3" pipe out the back, with a tip of your choice.
hth!
And you may ask yourself, "Where is that large automobile?"
