07-23-2021, 03:15 PM | #45 | |
Rep 323
07-23-2021, 04:37 PM | #46 |
Rep 2,758
Thank you for further confirming my posts.... Yes, swaps are def a pain in the ass, but you can swap most anything if it follows what I said in my first post
07-27-2021, 12:01 PM | #47 |
No one sleep in Tokyo
945
Rep 1,507
Drives: 2011 E90 328i//1995 E34 530i
Just when I was feeling nostalgic and missing California. Hahahahahahaha!
2011 E90 328i, 1995 E34 530i, 1992 E32 740i, 1991 E34 525i
07-30-2021, 11:38 AM | #48 |
Rep 323
Found another article with a good explanation of the new testing procedure: https://www.thedrive.com/cars-101/41...tune-flash-faq
Would be interested to hear if someone has failed after flashing back to stock or has passed despite a tune. Or what the process through the referee is like in the case of a fail. Anyone had their car smogged in the last couple weeks? |
540iSUP704.00 |
07-30-2021, 06:36 PM | #49 | |
Rep 2,758
07-31-2021, 11:16 AM | #50 | |
Go Spurs Go
3922
Rep 2,877
Ie no truck engines into cars and vice versa Now it is even harder as you can't even unlock Ecu for immobilizer bypass since it may create a different check sum and cause it to fail smog It's a lot of backwards laws happen, and it got worse It's not about emissions since a newer engine will ALWAYS run cleaner than one that is 20 yrs older If it was about cleaner air , they should ONLY care about what comes out the tail pipe |
540iSUP704.00 |
07-31-2021, 10:40 PM | #51 | ||
Rep 10,373
"Drive more, worry less. "
09-08-2021, 12:25 AM | #52 | ||
Rep 2,592
2015 BMW 535xi
________4160.00 |
10-29-2021, 10:42 AM | #54 | ||
Rep 248
Drives: 1989 325i & 2014 335i
It's so much easier, faster, and safer to check the computer versus putting the car on a dyno with a tailpipe sniffer. Quote:
Changing the tune changes the 1's and 0's, so you'll get a different checksum. Forcing a known-good value is a felony. You cannot pass the checksum using an aftermarket tune. Stock, MPE, Dinan, etc are all certified, so they will have a valid checksum. They also check to see if your ECU is locked (supposedly preventing tunes). Even on a stock tune, you will fail with an unlocked ECU. Hardware mods that can be controlled by a stock tune won't cause a checksum failure. But you'll fail the visual if it looks aftermarket without an EO number. |
StradaRedlands4974.50 540iSUP704.00 |
10-29-2021, 11:38 AM | #55 | |
Rep 1,812
Also, the ecus can be unlocked and tuned without any traces to CAL ID/ CVN, so it's still not exactly that different. I can unlock these M2C ecus without any trace at all, anywhere.
-2014 328d Wagon, 8HP. Self-tuned, 270hp/430ft-lbs.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. |
10-29-2021, 03:00 PM | #57 |
Rep 606
So I should be ok if I flash back to stock and lock DME just for the smog? Just want to plan this out before I start smog checks next year and what to prepare for.......
10-29-2021, 09:37 PM | #59 | |
Rep 2,760
540iSUP704.00 |
10-29-2021, 09:39 PM | #60 | |
Rep 2,760
10-30-2021, 11:32 AM | #61 |
Rep 1,812
The unlock is a data hack in the dme. It does modify the checksums/CVN, so it will still be considered "tampered".
11-01-2021, 05:38 AM | #63 |
________
4160
Rep 2,301
11-01-2021, 10:53 AM | #65 |
________
4160
Rep 2,301
11-01-2021, 02:14 PM | #66 |
Rep 1,675
Your not saying much of anything, neither is the guy who you are trying to defend
Commieofornia has just had its recall election stolen in front of everyone, whats happening there is a early indicator of what 'they' plan on rolling out to the rest of the country People need to say No! |
Tags |
california, ecu, ecu bmw tuning, n54, n55, piggyback, smog, smog check, tune, tuning |
