      07-31-2023, 01:54 AM   #1
Mert335d
Drives: E92 335d LCI
  [0.00]
Hello E6X Community,
i upgraded my K+DCAN Cable with the enhanced Firmware and I want to ask you, if there is any interest in buying an upgraded K+DCAN Cable.
Advantages over normal K+DCAN Cable:
- DME Flash of M3/M5/M6 without ECU corruption
- SMG Flash of M5/M6 without ECU corruption
- Gearbox TCU Flash of E6X,E7X,E8X,E9X without ECU corruption
- coding TRSVC Module in E6X,E7X,E8X,E9X when retrofitted
- read FSC directly with SWID Reader and K+DCAN (no ICOM needed)
- faster CAN Communication
- safe ECU flashes due to software fuses
Edit 1: (07/31/2023)
- MHD Flashes under 1 minute
- XHP Flashes with OTG much faster
So in general: much safer, faster and 100% reliable Cable than the normal K+DCAN cables.
This upgraded K+DCAN Cable can be easily updated with USB, no Soldering or Pins required.
The K+DCAN Cable will come with the latest FTDI Drivers.
It is still working for BMW/MINI Cars from 2000 until 2012. The switch position controls the connection before 03/2007 and after 03/2007.
If there is any interest, i would try to make a good offer !
You can PM me if so.
Thank you !
