12-26-2020, 02:51 PM | #1 |
Rep 906
Good telephoto lens?
I'm a hobby photographer shooting on a 80D and recently noticed that I've been maxing out the focal length on my EF-S 18-135mm f/3.5-5.6 IS.
I've been wanting to get something around 400mm range, but not break the bank. Lately, I've been renting a EF 100-400mm F4.5-5.6L IS II USM and the results are absolutely stunning, but it's glass that's really out of my budget. Can anyone recommend a good alternative? Shot at 360mm on EF 100-400mm F4.5-5.6L IS II USM
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World |
12-26-2020, 04:13 PM | #3 |
Rep 7,457
Canon's 70-300mm (non-L) is a decent lens. Not quite the reach of the 100-400, but it's under $600. Note that you should avoid the 75-300 lens. That one is junk.
https://www.amazon.com/Canon-70-300m...dp/B01LXTX4WY/ There's also the Sigma 100-400 for about $700. https://www.the-digital-picture.com/...rary-Lens.aspx
12-27-2020, 12:30 AM | #6 | |
Rep 125
On your 80D, the focal length is actually 1.6x longer due to the crop sensor so the 100-400mm is effectively a 160-640mm. I shoot fashion as a hobby and use fairly expensive and fast lens such as the Canon 70-200 II 2.8 and Sigma 120-300 2.8. Both are heavy but are super sharp and great in low light. Samples of shots attached. I prefer constant aperture lens (ie fixed aperture at all focal lengths) and fast aperture but if you're shooting landscape, it doesn't matter when using a tripod and a remote. The more affordable zooms don't have constant aperture or are as crisp as the premium lens but they will work fine if you know how to use them The Sigma 150-600 and Tamron G2 are good affordable long zoom with the edge going to the G2. (Stay away from the older versions of these lens). https://www.bhphotovideo.com/c/produ....html/overview https://www.bhphotovideo.com/c/produ..._5_6_3_di.html And learning to use Photoshop Elements or another editing tool will do wonders for your pictures. PS Elements has a guided mode if you don't want to deal with the complexity of manually editing. |
Littlebear3511.50 |
12-27-2020, 01:17 AM | #7 | |
Rep 906
Canon EF-S 10-18mm f/4.5-5.6 IS STM Canon EF 50mm f/1.8 STM Canon EF-S 18-135mm f/3.5-5.6 IS I usually shoot landscapes as part of my travels and had been using my 10-18 more. This one was shot at 10mm, f/7.1, 1.3s, ISO100 However, I've recently starting using my standard zoom lens more to capture subjects from farther away. This was one example where I hit my 135mm cap, taken on my last trip before the pandemic hit: 135mm, f/5.6, 1/1250, ISO100 And thanks for the recommendations! Sigma 150-600 sounds ideal, and I see it for $819 on the outlet store. It's a bit of a stretch of the budget, but I do like that it goes up to 600mm.
12-27-2020, 01:59 AM | #8 |
Rep 265
The Sigma and Tamron 150-600s are about the same in image quality, so that might expand your search. Don't be afraid of used gear. Check out keh.com, natcam.com, and mpb.com. I've bought stuff from all 3 and have never had a bad experience.
Littlebear3511.50 |
12-27-2020, 07:07 AM | #9 |
Rep 1,336
Drives: Porsche 993
So I used to shot a lot more than I do and I've just started getting back into it. Since nobody has mentioned it yet have you considered used. We have a place called Henry's in Canada, they are a pretty big chain and usually have a good selection of used equipment and I think they stand behind it with warranty etc. You might get more lens for your budget than going new. Just my two cents.
https://www.henrys.com/Categories/29...al-Lenses.aspx |
Littlebear3511.50 |
12-27-2020, 08:37 AM | #10 | ||
Rep 125
Be aware that they are both heavy lens in the range of 7 pounds.A tripod is recommended for for steady shots, low light and long exposures |
M_Six17269.50 |
12-27-2020, 11:45 AM | #11 | |
Rep 7,457
I'm not trying to talk you out of the 150-600. I'm just highlighting the weight consideration.
12-27-2020, 12:16 PM | #12 | |||
Rep 906
12-27-2020, 12:38 PM | #13 | |
Rep 125
Sigma 120-300 2.8 is a bargain compared to Canon L lens. Nice shots btw. Love the airplane and insect shots. |
12-28-2020, 11:02 AM | #14 |
Rep 3,061
Depending on your budget, perhaps a used EF300/4LIS or Sigma 180-300/2.8 would be good options. I borrowed the Sigma to shoot a hockey tournament and was impressed.
12-30-2020, 01:53 PM | #15 |
Rep 906
My local Samy's Camera had the Sigma 150-600mm f/5-6.3 DG Sports lens for rental, so I took it out for a spin. The Contemporary version of this lens wasnt up for grabs.
ISO100 600mm, f/10, 1/640s ISO200 210mm, f/10, 1/80s I havent had time to ID the differences between the Sport and Contemporary versions of this lens, but I agree this thing is big and heavy. The Canon 100-400 I rented last time could at least fit in my bag, but this Sigma lens has its own bag! As expected, I'm probably going to need a beefier tripod as this setup is prone to wobble, but I can work that out. I'm also running into some whitebalance issues at 600mm, when subjects are really far away (40 miles). Not sure if its just me, the UV filter, or the lens.
12-30-2020, 06:28 PM | #16 |
Rep 7,457
Nice images. Love the compression.
My Sigma 120-300 f2.8 is also a beast. Even on a beefy tripod, and using a lens foot, it's still a bit wobbly. Trying to get something like the moon to stay in the center of the lens for fine tuning manual focus can be a pain. I have a 3-axis tripod head that helps, but that's also quite beefy. So between the lens, the tripod, the tripod head, and the 5D MkIII with the battery grip, the whole kit weighs in at slightly less than a ton. (Ok, not quite that bad, but close.)
12-30-2020, 06:40 PM | #17 |
Rep 881
Try to get a lens with a 2.8 aperture. It will allow you to do a lot more.
2018 F80 M3. YMB/BLK. ZCP. Three Pedals.
"Education will never be as expensive as ignorance." |
12-30-2020, 09:44 PM | #18 | ||
Rep 265
12-31-2020, 11:44 AM | #19 |
Rep 906
12-31-2020, 12:16 PM | #20 | |
Rep 265
12-31-2020, 01:32 PM | #21 | |
Rep 7,457
01-01-2021, 10:53 AM | #22 | |
Rep 265
I have the same ball head on a monopod too for shooting motorsports, which I usually do at Road America. That's a fantastic combination. Absolutely no help to your situation lol |
