E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Would new Xenon Ballast affect Adaptive Headlights?
Reply
      05-10-2024, 09:14 PM   #1
krc70
Drives: 2008 335ix, 2000 540i
Hello. Apols in advance if this question has been raised and answered before. If so, I couldn't find it. I have an '08 335ix. The drivers side low beam went out. Wasn't the bulb, so replaced the ballast (non OEM) and it works now. However, not long after, I got a Adaptive Headlight malfunction. I tried changing the drivers side control unit (again, non OEM) but didn't work. I then swapped with the passengers side control unit, but still didn't work. Wondering if the new ballast is causing this and the Adaptive HL control units are fine, or something else? Even though the new ballast worked right away, would I have still needed to have it coded for it not to be affecting the Adaptive HLs? Any thoughts are appreciated. Thanks
      05-10-2024, 11:48 PM   #2
cod3
Drives: 2011 bmw 335i
2011 bmw 335i  [0.00]
Yeah you are going to have to code them in but once you do that everything should be fine
      05-11-2024, 09:35 PM   #3
Nando_e90
El Salvador
111
Drives: 2006 E90 330i
Happened to me with non-adaptive but self leveling xenon. Last week replaced the ballast with a used genuine one and although it worked, the self leveling function stop working and the lights aimed all the way down.
INPA showed 9CB6 FRM error code: Headlight beam height control coil break
I still haven't found a solution
      05-16-2024, 09:09 AM   #4
krc70
Thanks for sharing!
      05-16-2024, 09:11 AM   #5
krc70
Hope you find a solution
      05-19-2024, 10:57 PM   #6
cod3
I would be willing to bet that you have a wire that has developed some kind of break in it. Id recommend removing the bumper to remove the headlight affected and opening up the rear panel on the headlight to examine all the wires that go to the motor inside the headlight.
Nando_e90111.00
      05-20-2024, 06:29 PM   #7
Nando_e90
El Salvador
111
Thanks for the input.
That's a good point. I haven't opened it up again after ballast replacement. Will do it on the weekend and see if I find something.
Reply
e90post
