02-01-2013, 07:59 AM | #1 |
Rep 96
Brakes failed today down hill need hill pedal went hard
Hi guys i was driving down hill today and the engine note changed and exhaust sound went slightly louder and all of a sudden brake pedal went hard and brakes didnt work
The pedal had gone quite hard and wasnt going down I managed to luckly use handbrake to slow car down hill and parked the car up I have checked the brake fluid and its at the correct level the pedal doesnt go fully down and feels hard I checked the vacuum pipes on the turbo and the vacuum line didnt have any suction this indicated that the vacuum pump is at fault as there was no suction And i know that the engine sound is ment to change when i disconnect the vacuum from the turbo as its changes the turbo vanes by vacuum as i have tested before this fault this time it didnt change engine sound Is the brakes powered by the vacuum function too? The discs and pads are all good changed 2 months ago no leaks on any caliper as pressure is there pedal not dropping to the floor Any one had a vacuum fail or know of the symptoms? And if this is at fault how hard to fix thanks |
