02-24-2022, 05:45 AM | #1 |
Rep 880
Router and Wi-Fi set up
Currently using Google mesh Wi-fi with 5 nodes to cover 3400 sq feet with 2 floor and a basement, So 3 levels.
Wi-Fi speeds are good as I’m getting at least what I’m paying for. Pay for 200/35 and getting 199-230/35. I have a 5g main network almost everything is on and a 2.4 guest network for guests but also has my smart lighting bridge. Currently about 34 devices and I’m looking to upgrade the router to future Proof my Wi-Fi. Seems everting I read had downsides Though EERO pro 6 (3 pack) would do it but at a high cost. But I seems lots of users have issues where the devices don’t connect to closest node Effecting speed. Also do I need to hard wire these for best backhaul? Or is the 3rd band sufficient ? Thanks for any insite into routers and set up philosophy. I’m not to up on it. Last edited by jsf721; 02-24-2022 at 08:33 AM.. |
02-24-2022, 06:15 AM | #2 |
Rep 1,328
Ive been rocking the ASUS XT8 system using the wireless backhaul since the start of the pandemic and I can get my 800+ down, run multiple HD streams locally from media server, and have about 35 devices on at any given time. I also use it as a backup NAS, like a time machine, since it has USP ports for drives and can run a SAMBA/FTP server.
The only knock is if you want to use QoS it uses a cloud service in China so I nixed that shit. |
M_Six17315.00 |
02-24-2022, 07:09 AM | #3 |
Rep 7,457
That Asus XT8 looks like a sweet system. I've been wondering where to go once my Apple AirPort mesh starts to die. Knock on wood, it's still working great.
Does the Asus system have decent configurability?
02-24-2022, 08:56 AM | #5 |
Rep 433
Both Ubiquiti and Belkin owned Linksys have excellent cloud managed access points that work remarkably well with mesh setups - no issues with client roaming in the setups I've done
02-24-2022, 09:03 AM | #6 |
Rep 3,242
I detest any cloud managed networking systems. You're totally dependent on the manufacturer to keep that product operational. So in essence, you don't own your equipment and are just leasing it.
I'd look into a system from Aruba called Instant Access Points. Due to firmware limitations with my equipment which uses a Dell OEM'd wireless controller from Aruba. I can't upgrade it past the current firmware to support the newer access points despite the 7008 controller I own as still being current. But even with that limitation, I'm able to do file transfers at a real world rate of 400 to 500 Mbps over wireless. I don't see myself needing to upgrade any time soon. This performance more than satisfies what I need when I'm moving about my home on any mobile device. It also more than satisfies 4k streaming uncompressed. If I need to really push bits, I just go to my wired desktop or just connect up my laptop to a network drop. The network drops I can connect any client device up to supports 1Gbps and 10Gbps. |
jmack550.00 |
02-24-2022, 09:04 AM | #7 | |
Rep 1,328
You can individually optimize signals and test, bind devices to a specific node, they come with wired connections at each AP, can to wired backhaul, etc. The app lets you check the dba of each device, etc. You can monitor the routers performance as well, CPU, memory, throughput, etc. I'm actually running my media server on my remote node wired and it really helped with multiple 4k streams I think because now its not sending and receiving the whole thing wirelessly. And the wireless backhaul doesn't miss a beat. I just ran a test and the media server and got an average of 762.6 of the 800Mb/s Im paying for. I have the option to put in wired backhaul since my house is pre-wired with cat6 but since it works so well Ive been too lazy to mess with it. And then of course all of the family stuff, access control, scheduling, etc. The stuff that everyone else does that I dont use anyway. |
02-24-2022, 09:06 AM | #8 |
Rep 3,242
Something else of note which is not being discussed. You can have the fastest wireless APs available. But if your clients can't support the capabilities of the APs, you're wasting your money. You have to look at how many streams the wireless NIC in the client device can support. Many wireless clients only have a 1x1 or a 2x2 wireless NIC in them.
02-24-2022, 09:08 AM | #9 |
Rep 7,457
So you don't use another router between the Asus system and your modem? If so, how configurable is the firewall on the Asus? Can you create your own rules?
02-24-2022, 09:12 AM | #10 | |
Rep 433
Keeps me from pulling out what's left of my hair... Another 'backup' option I look into is - if the unit can be managed without the cloud service - so yes you do lose the remote management piece unless you have some local controller, etc. |
02-24-2022, 09:13 AM | #11 |
Rep 1,328
No the asus is the router, I just have a motorola surfboard modem (my own) connected to Comcasts cable.
You can set up to 128 individual firewall rules, can use remote IP, port or protocol. You can also filter sites, keywords, services. For fun I was blocking fox news when my dad was visiting just to annoy him. FYI the Asus system is basically just multiple routers. Its not the main router and then "dumb" pucks. They basically just developed a mesh protocol that all of their routers work with. You could, in theory, use one of their massive gaming routers as the main one and the others as the nodes. Really all you are doing is installing full routers and just designating the primary and nodes. |
M_Six17315.00 |
02-24-2022, 09:14 AM | #12 | |
Rep 7,457
TiMSport12808.50 |
02-24-2022, 09:16 AM | #13 |
Rep 1,328
Also FYI I havent really played with it but their routers have IFTTT and Alexa skills. All I can really think to do is maybe turn the guest network on/off. I never turned on the guest network so I havent played with it.
I guess with kids you could shut their internet off using a skill or something. |
02-24-2022, 09:26 AM | #14 | |
Rep 3,242
paquet629.50 |
02-24-2022, 10:33 AM | #15 | |
Rep 1,328
My router has WAN management options but unless youre running a static IP not much use. |
02-24-2022, 11:07 AM | #16 |
Rep 290
When I moved last July, I bought the Orbi RBR850 - primary and a satellite unit
pretty happy with the performance and config options I pay for 1.2Gbs and regularly get test results of 1400+
2019 YMB ZCP convertible with Dinan Exhaust
2011 Ducati Diavel Carbon Edition 2015 BSM M4 Convertible - 2018-2019 2016 228Xi - 2017-2018 2003 Acura RSX Type S 2003-2017 |
02-24-2022, 11:15 AM | #17 | |
Rep 3,242
Most consumer grade routers have support for dynamic DNS. You just configured your login credentials into the router. The built in client will report any new IP address assignment to your router's WAN port to the dynamic DNS service. Been using dynamic DNS for coming up on 10 years without any issues. |
vreihen1615625.00 |
02-24-2022, 11:31 AM | #18 |
Rep 1,328
the asus does support DDNS I just suggested chrome remote for the layperson who might not want to go through all of that but still thinks they need remote management.
02-24-2022, 11:33 AM | #19 |
Rep 7,457
I have a domain name that points to my home as well. But my IP changes so rarely I don't bother with dynamic DNS. In the 10-12 years I've been with my cable provider, I've only had 3 or 4 IP changes. But in general I agree, dynamic DNS is easy to use and is included in many routers.
02-24-2022, 11:58 AM | #20 |
Rep 3,242
There are other options such as Teamviewer for remote management. Call me paranoid, but I just don't trust anything from the likes of Google, Amazon, etc where part of their revenue model is collection of data.
Frostynorth432.50 |
02-24-2022, 12:34 PM | #21 |
Rep 1,328
Oh yeah feel you. I didnt mind it because its just on my HTPC server which has nothing on it but plex and MKVs and the account its tied to is a "whatever the fuck Google is calling G Suite now" domain so the accounts are separate from their data collection apparatus. I would have had to enable it as a domain admin and did not.
02-24-2022, 12:35 PM | #22 | |
Rep 1,328
Not that I would, I have only logged into my server to see if it was the network or something else that knocked my cameras offline, etc. Which has been a WHILE. I just keep my domain because it belonged to a business I had so its kind of sentimental. |
